Results 1 to 5 of 5
Thread: Bing carb question, 1982 R100RT
    Aug 2007
    Somers, CT
    My bing carbs seem to weeping gas from what looks like a little brass pin located just to the side of the "bing" label near its bottom edge, picture attached. What is this pin? Is it a swaged in plug? Can i simply put a little epoxy over it to seal it or is it some type of vent? Thanks in advance.
    Jim O'Coin
    DeLand Florida
    I would not seal it, but instead look into the reasons the gas is leaking. Is the float set wrong resulting in the gas being too high, or dirty seat, worn seat. A bit of troubleshooting will solve this without modifying the carbs. My last airhead would do this from time to time due to swelled floats. Once in awhile, after being parked a while, they would stick in the float bowl, preventing the valve from shutting off the gas. New floats, along with a few other needed parts, was all it took.
    Wayne
    MOA,RA,ABC,NEF,MCPR,MOAL brownie's Avatar
    Pensacola, FL
    Thumbs up Checkout Snowbum's Carb dissertation
    Search "Snowbum Carbs"......you'll find out more than you want on Airhead carbs......excellent discussion(s) on Bing issues!!!! BTDT recently....don't know enuf to help you... : (
    Words to Ride by: Patience, Anticipate, Paranoia
    Shep Brown MOA 27510
    "Igor" 82 RS "Inga" 04RT
    Pensacola, Flairider
    Aug 2007
    Somers, CT
    I do plan on digging into the carb (i've rebuilt them before) but i was unsure the function of the feature i made mention of. If is just a plug, no harm in sealing it. There is no way to seal it otherwise, by peening that is.
    Jim O'Coin
    Mike V. #30064 30064's Avatar
    May 2006
    San Diego, CA
    Jim,
    I wouldn't disturb that pin unless you are 100% sure it is leaking. I agree with toooldtocare's advice above. I'm guessing the discoloration may not be coming from the pin you're speaking of but the bowl overflow vent located just behind and slightly under the black Bing badge. See it?
    Mike V. / San Diego
    MOA#30064 / ABC#11027
    78 R100/7 [orig. owner] / 81 R65 [restored]
    ABC-MOA-AMA-VBMWMO / http://tinyurl.com/4df7hgs
