Results 1 to 15 of 22
Thread: Throttle Lock?
    Jul 2010
    Eugene Or.
    Throttle Lock?
    I never realized how much I used or enjoyed the cruise-control on my old R75 until I got the new F800. I've been searching for some options and I'm looking for some advise and opinions. I've got a 2013 with the BMW factory hand-guards installed and need to find something compatible with this arrangement, (I see the Kaoko model says it's compatible on F800 with "retro-fitted 1200 hand guards" but I'm not sure if those are the same as the now-available F800Gs hand guards and I'm not ready to take a $120 guess!)
    Are any of you using a throttle-lock on your F-bike, what kind and how does it work for you? Thanks in advance for any insight. -Paul
    1970 R75/5 Old Faithful
    2013 F800GS New Flame
    Feb 2005
    Redmond, WA
    Throttle lock
    Quote Originally Posted by bustedknuckles View Post
    I do not know anything about the Kaoko "Cruise Control" other than it is probably not 'cruise control'. To retro fit true cruise control would involve more than clamping on a piece of handle grip hardware.
    ThrottleMeister has just introduced a unit for the 2013 F800GT. Order carefully, as the part number is just one digit different that for the F800ST. If I recall, the P/N is AB20-H. I just installed one on my GT. Trickey part is getting it correctly set with and without the grip heat on. $140.00 satin HD with heavy end caps. I also use a $10 Cramp Buster (aka, wrist rocker) when I am too lazy to set the ThrottleMeister. Both are installed on the twist grip simulaneously.
    In another note, I have over 1,500 miles on Mark Stadnyzk's MadStad 'beta' test windshield for the 2013 F800GT. Works great. I passed on a few suggestions based on my install/use experience that Mark plans to implement. Hornig (Germany) now has mirror extenders for the GT. Not necessary for MadStad windshield use but they do give you a somewhat better view aft. Although their web site lists the standoff as 5 cm (50 mm), the delivered item only provides 25 mm of standoff. 'More better' than zero standoff.
    Good luck.
    Grumpy...
    2013 in rusty orange
    Registered User David13's Avatar
    Nov 2011
    Lomita, California
    I had a Kaoko on my 800ST. They lock but they are nothing compared to the cruise control, the real one.
    The Kaoko would always either accelerate, or decelerate. No happy medium.
    It was just another of the reasons why I decided to go back to the RT.
    dc
    Jul 2010
    Eugene Or.
    Thanks guys, I know that nowadays bikes are available with actual electronic cruise-control but I really just want the ability to take my right hand off the grip for a few moments while cruising, I understand these types of throttle locks are not terribly accurate at retaining an exact speed for a long time but I've found a 30 second rest of the throttle hand can be a welcome thing on a long ride...
    Registered User dadayama's Avatar
    Sep 2009
    Oklahoma City
    I use a Kaoko with Tourtech hand-gaurds.
    I've had the Kaoko on the bike for 2 or 3 years and and am happy with the it... I use it a bunch, and have done a fair amount of long distance travel. I wouldn't want to ride without a throttle lock. A throttle lock is not cruise control, but i don't think it is that hard to regulate speed as other have stated.
    Hope that helps
    Pedro
    Ich Fahre Nicht Zu Schnell, Ich Fliege Nur Niedrig
    Oklahoma Adventure Trail
    Registered User Moto316's Avatar
    Nov 2007
    Phoenix, AZ
    Try the "Go Cruise" throttle control. Installs on any throttle grip in seconds. Very easy to use. A lot of motorcycle shops sell them, also on line at Aerostich, etc. only $20!
    Jul 2010
    Eugene Or.
    Quote Originally Posted by Moto316 View Post
    Hadn't seen this before, simple and effective. Thanks!
    Cage Rattler wezul's Avatar
    Nov 2006
    Glen Ellyn, IL
    Crampbuster?
    10 bucks MAX.
    Like eight and a half if you look.
    Cool
    Three months ago I purchased, at Pandora's in Chattanooga, TN, a Kaoko for my 2012 F650GS with factory hand guards. I had been the bike for just over a year when I installed it. All I can tell you is that I will not ride any bike...any big distance without one. I know that there are others, but this one ROCKS!
    http://www.pandorasmotorsports.com/
    http://www.kaoko.com/pCCF900/KAOKO-C...andguards.aspx
    Registered User andreb's Avatar
    Jun 2009
    De Forest, WI
    Wunderlich Throttle Lock
    I originally purchased a Wunderlich throttle lock. It was a beautiful piece of metal and worked smoothly. But it had a fatal design flaw. It rotated in the opposite direction of the throttle when engaging or disengaging. This made for abrupt on and off, I was always chopping my throttle and making my motorcycle slow down or speed up. Very annoying. A Throttlemeister was not available for use with a handguard.
    I now have a Kaoko throttle lock on my F800GS, which works with the OEM BMW hand guard. It works well. Not quite as well made but it is a bit cheaper and will not wear out.
    Andre Boening
    2010 F800GS and 2012 K1600GT
    Jul 2010
    Eugene Or.
    Thanks for the replies. I think I'll go ahead and order the Kaoko since it nicely integrates into the handle and sounds like it works as advertised. This kind of info is what makes this forum great. Thanks again. -Paul
    Registered User markdemshock's Avatar
    Aug 2013
    Mukilteo, WA
    Does anyone know if these will fit the F800ST as well? I've looked at several of them and they're all listed for the GS/GT.
    vancouver ,wa
    Kaoko
    I have a 07 F800st with a kaoko on it. There is two locks for this machine, the differance is the type of screw in the end of the bar weight. Contact the supplier or your dealer to help you out.
    Sep 2012
    Lansing, Kansas
    Like you, I only need a brief chance to flex the fingers of my right hand occasionally--and then only when I am buzzing along on the slab. I find that when I am "more involved" with the throttle (i.e., constantly slowing and accelerating, as on back roads) I do not seem to need to give my right hand a break. I use the $20 solution (don't know the name) that simply slips over the grip and fits tightly on a rubber band. Works great for me and it certainly maintains my speed for the few minutes that I use it.
    Royce
    On the coast of Kansas
    2012 F800ST
    172526
    Jul 2012
    Just ahead of a flat line
