Results 1 to 7 of 7
Thread: 2004 R1150RS Fuel tank Connector
    Savannah, GA
    Bought bike used recently and removed the tank to install farkle and found the tank connector it tough shape :
    It was wrapped in electrical tape, holding the broken part of the connector and ty-wrap'd also. My question, is this connector available and are the any special tools needed to push pins out. I looked at Bob's fish but didn't recognize any of the connectors.
    Florida & Massachusetts
    There is a tool, I'm just not sure where you'd find it. I've usually improvised.
    If the female half is intact, mate the connectors, use a tie-wrap from end to end, and give it a wrap with tape, just like it was. In the meantime you could try drew at max BMW. You might try an electrical supplier who carries AMP.
    It's taken me months to come up with three different O2 connector pairs but I think I'm just about there.
    Mar 2013
    Winnipeg, MB, Canada
    Try this link: http://www.powerandsignal.com/Images...Connectors.pdf. Snap-On and Mac have great connector kits for almost all makes.
    Mar 2013
    Oh, I should have mentioned, Cummins and International on the Maxx-Force engines use the same connectors. I got mine from the scrap pile at an International dealer.
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    I have a connector and can supply you a pin extraction tool.
    PM me.
    Ufda happens..........
    Savannah, GA
    PM me.
    thanks
    rsbeemer 22600's Avatar
    Jan 2011
    New Braunfels,Texas/Taichung, Taiwan
    Not about connector
    I used to have a 2004 r1150rs....so thought I might mention changing out the plastic quick fuel disconnects for the newer metal versions if you had not already done so. One of mine cracked when I was about 2500 miles away from home and started spurting gas out everywhere. Finally made it to a Napa dealer and jury rigged it until I got home. I found out later that it was a problem on many newer bikes. Took a long time for BMW to correct it and put the metal ones on there. It was a nice running bike when everything was working right but it was to much technology for me. I went back to my old airhead.
    DW
    1978 R100rs MOA#22600 125cc Kymco , 180cc Kymco Racing King
    The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails.
