Results 1 to 13 of 13
Thread: Hi, new and already have a transmission repair question.
    Hello, David House here. I've been the proud but frustrated owner of an 83 BMW R65 since December 2012. Rebuilt the carbs, replaced the coil and the engine runs great. But.... when I took it out for a test ride yesterday, was winding through the gears and from 4 to 5, the tranny made this sound of dogs and gear slots not meshing. Sound stopped upon deacceleration. The bike still shifts through the gears, but only at the lowest of throttle. If any torque is applied in any gear, the grinding sound occurs. Do I have a tranny rebuild on my hands? Any suggestions for a quick fix?
    Mar 2008
    DeLand Florida
    Does not sound healthy. My first BMW I bought new, a 1986 R80RT that ran perfect until one day it did pretty much as yours. My problem turned out to be stripped splines in the clutch and input shaft. The bike had about 35K on it at the time. Whatever it is, it needs to be looked at.
    Wayne
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    Have you drained the gearbox and checked the oil for metal? Take out the rubber timing plug and see if there is any metallic dust inside. Stick a pencil magnet in and see if anything sticks to it.
    Wisconsin and Florida
    If you are not absolutely sure the sound comes from the transmission do not forget
    Splines at rear end of drive shaft
    Spline cup in rear wheel
    Registered User dmftoy1's Avatar
    Mar 2012
    Lexington, IL
    No suggestions for a quick fix but had Tom Cutter at rubber chicken racing garage go through my r90/6 recently and he treated me fairly. Tranny shifts much nicer now.
    Good luck,
    Dave
    Administrator 20774's Avatar
    Pull the rubber boot back where the tranny is bolted to the driveshaft...make sure all those bolts are in place and tight.
    Registered User krpntr's Avatar
    Mt Vernon WA
    And if they are tight get some new ones because your going to pull the trany. If they are lose, replace them.
    Fenwick, Ontario Canada
    Quote Originally Posted by Krpntr View Post
    I have used those bolts multiple times over.
    I keep a set just in case but If you can thread them in easily by hand they are OK.
    From a retired metallurgist.
    Knights of the Roundel #333
    Thanks, all
    Thanks for all your responses. Will check out all suggestions, including finding a reputable BMW repair shop to work this problem out. Sounds like it is beyond my capabilities.
    Pismo Beach, CA
    Name your location, there are folks here on the boards spread out all over the US and Canada; some one will know of a shop that can help you out. There's also the Resources & Links page to refer to.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Newbie's location.
    Quote Originally Posted by lmo1131 View Post
    I am located in Rehoboth, Massachusetts, about 10 miles east of Providence, RI.
    Sounds like the ears are broken off the input shaft gear. It does exactly what you describe, and it's a known issue for those years.
    Mar 2010
    Vancouver, B.C. Canada
    Quote Originally Posted by dlhouse51 View Post
    Welcome the to forum by the way!
    RE: your location
    I think he means edit your profile to include your location.
    Having the bike you own in your signature area also helps readers.
