Results 1 to 7 of 7
Thread: Turn signal indicator always on.
    Registered User jcofwmburg's Avatar
    May 2005
    Williamsburg,VA
    This just happened today. Left the house on my 74 R90/6. Turned the key to turn on the headlight and the turn signal indicator on the instrument cluster came on and stayed on. Everything functions. The turn signals work normally. What causes this? The light is on in any key position that other lights are on. It does not blink with the turn signals, it's just on all the time.
    Registered User Battleborn_BMW's Avatar
    Apr 2010
    Spanish Springs Nevada
    If you figure this one out let me know. My '75 R90/6 randomly does the same thing. I'm guessing connection on the instrument cluster flex circuit board. I haven't found the culprit on mine yet. The issue on mine comes and goes. As with yours all else works fine including turn signals.
    Feb 2009
    Chicago, IL
    May be time for a new flasher relay. There is an inexpensive option at your local NAPA if you're cheap like me. : )
    You may also want to check your turn signal grounds (all the brown wires).
    May 2005
    Williamsburg,VA
    NAPA fix?
    Quote Originally Posted by photorider View Post
    As the turn signals work I don't think the ground connections are the problem. It may be the relay, probably is, but it's fairly new, replaced a year ago or so. Tried a "Airhead" fix from Matt Parkhouse but it didn't work well for me. So what is your NAPA fix?
    Pismo Beach, CA
    Tridon/Stant #550 ; $7-10 (don't know if NAPA sells them but I'm sure they can cross-reference it)
    Read -> http://forums.bmwmoa.org/showthread....n-Signal-Relay
    Part substitute links
    Airheads - http://www.airheads.org/content/view/159/98/
    IBMWR - http://www.ibmwr.org/otech/partsubs.shtml
    Snobum's thoughts on the subject start on line #23 (near the bottom of the page) -> http://bmwmotorcycletech.info/electricalhints.htm
    Lew Morris
    1973 R75/5 - original owner
    Braintree, MA
    Put some black tape over it.
    -Tom (KA1TOX)
    Mine is intermittently on also. Then it works right for awhile. Seems to be related to the rain. After it dries out out it does it less. The turn signals are still working but I don't always know what they are doing. Started this symptom only a few days ago.
