Results 1 to 3 of 3
Thread: k75s Windshield Repair
    Joe T joetk75s's Avatar
    Apr 2004
    North Providence, RI 02904
    My OEM windshield is broken and I would like to try a repair. Has anyone had any experience with this?
    The area that is broken is the lower left tail that wraps around the headlight. See image attached.
    Thanks for your help.
    JT
    Joe T
    Trying to get it right
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Good Luck! That area is very highly stressed. Any repair that looks good will probably not be strong enough at speed.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Registered User Paladinwest's Avatar
    Jun 2010
    BC South Central Interior
    I did a repair on my 1990 R100GS PD that was broken in a similar place. It was complicated but it did last quite a long time after the initial break. I took the windshield off the bike and cut a groove down both sides of the break with a dremel tool. Then I drilled a series of small holes on each side of the break for the length of the break (about one hole every 3/16th of an inch). Clean all the debris out of the area and then stitch the two pieces together (I used brass wire from a hobby shop). Mix up a batch of epoxy and layer it over the groove and into the holes that the wire passes through. Do this on both sides and make sure that the epoxy goes through the holes and joins front to back. I went fairly heavy on the back side because it was not really visible and tried to make the front blend in as best I could. The old style PD windshield did have an advantage over the K75S in that it was painted black on the lower inside so it did camouflage the repair a bit. I probably put 40,000 miles on the repair including one trip to Inuvik and lots of rough back roads. I think that I had to renew the epoxy once when someone used the windshield to steady themselves as they tried to put on rain gear.
    It's not perfect but it saved me $150 or so. YMMV
    Quote Originally Posted by joetk75s View Post
    JT
    2014 R1200GSA 18,000, 2008 HP2 Sport 11,000, 2008 R1200GSA 100,000 (Sold), 1990 R100GSPD 100,000, 1986 K100RS 152,000
