Results 1 to 5 of 5
Thread: R1100RT Horn
    No longer a member here
    Apr 2006
    R1100RT Horn
    The horn on My '99 R11RT quit working. Everything else seems to be O.K. Is there a separate circuit with a fuse?
    Oct 2011
    Florida & Massachusetts
    http://www.mac-pac.org/tech/electrical-diagrams/
    See fuse 4 page 3.
    Mar 2010
    Vancouver, B.C. Canada
    Hey mine too!
    1) Yes there is a fuse. Fuse 4 count in from left side of bike. Mine was good.
    2) I swapped the horn relay with one of the other four identical ones and it still would only make a "doink" sound.
    3) I pulled the horn off, (13mm nut) checked the electrical contacts and cleaned them although they looked fine. Plugged it back in and still would not work.
    4) Next I tried moving the adjuster bolt on the back of the horn while my buddy pushed on the button. Still no worky.
    Next I will pull it out again and try it directly connected to a battery. Only the switch and the horn itself remain as possibilities. I think maybe the horn be toast. Update later...
    whoops, Roger is quick!
    Probably a little corrosion in the horn switch in the handlebar pod.
    Apr 2006
    Thanks guys! Will start exploring this weekend. Will report findings!
