Results 16 to 22 of 22
Thread: 03' RT Headlight Fuse?
    Florida & Massachusetts
    Quote Originally Posted by happy wanderer View Post
    I see what is going on here. Doug Raymond has released several versions of the 1150RT schematics.
    R1150RT_Elec_Diagram-v1_1.pdf
    R1150RT_Elec_Diagram-v2.pdf
    R1150RT-Electric-Diagram-V3.1.pdf
    and now
    R1150RT-2-Plug-Elec-Diagram-V1_1.pdf
    which is for the twin spark R1150RT
    Now we all know the company line that there have "never been any issues" but even so, it seems BMW decided to fuse the headlights on the twin spark 1150 according to Doug Raymond's schematic for that model.
    Knowing that there was almost no documentation on the dual-spark schematic, I worked with Doug Raymond over the winter to get him the documentation to update both the single-spark, and then to create a dual-spark schematic. Doug put a lot of time and energy into the updates.
    Here is the newest link to all the Doug Raymond schematics.
    http://www.mac-pac.org/tech/electrical-diagrams/
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    Turned the lights on, one at a time, pulled the fuses, one at a time ...
    Edit: I provided Doug with the info to do the dual-spark schematic since I have the disks.
    Wow, they actually changed in the end model run................I wonder if there are any other models where the same has happened....
    I suspect the warranty issues got back to the fatherland.
    Thanks for the info (as always)
    Ufda happens..........
    Vancouver, B.C. Canada
    Thanks Roger. I could net get to the schematics tech page without a login ID. Direct link works.
    I see the archived versions are gone now but I still have them.
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    Ve absolutely forbid zees fuzes to blow! Zey vill carry ze current und zey vill enjoy it!
    Aug 2012
    Farmington Hills, MI
    http://forums.bmwmoa.org/showthread....ectrical-issue
    http://m583.photobucket.com/albums/G...%20Fuse%20Mod/
    http://advrider.com/forums/showthread.php?t=665648
    FYI: the F650's have unfused circuits as well, I have redone & fused the harness on one of those as well.
    GSAddict -
    Thanks for the response and links. I had a short in the headlamp circuit caused by a self-inflected rookie mistake - a lamp wire got pinched when I reinstalled the tachometer into the instrument housing. Fusing the headlamp and ignition switch is a worthwhile project.
    Ken S
    03 R1150RT
    Quote Originally Posted by nosvamos View Post
    GSAddict -
    You are most welcome.
