Results 1 to 15 of 22
Thread: 03' RT Headlight Fuse?
Hybrid View
    Aug 2012
    Farmington Hills, MI
    Does the 03' RT headlights have fuse or circuit breaker protection? I've been looking at Doug Raymond's ladder wiring diagram and it appears the headlights are powered directly from the load relief relay.
    Ken S
    03 R1150RT
    Quote Originally Posted by nosvamos View Post
    no definitive answer, but I can not think of a bike that has the headlight on a fuse. it really does not make a lot of good sense to do so, unless you consider a headlight to be an "accessory".
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    No it is not.
    No oilheads are.
    Yes it is has caused many a melted harness.
    The ignition switch circuit is also unfused.
    Basically stupid design by BMW.
    Years ago I confronted BMW Canada regarding this and initially they denied the fact, when I referred them to the factory OE wiring diagrams and walked them thru their comeback was "we have never had an issue"
    History has proved them wrong.
    The most common failure has been caused by sloppy wiring practices when inmates add HID lighting on their GS's - shorts inside the lampholder.
    Others by chafing or poor accessory installation as well as upsizing to 100w lamps.
    I have modified several bikes now (including mine years ago) by adding a 20A fuse to the Load relief circuit and a 10A fuse in the Ignition switch circuit.
    There are several threads on how to do this mod. on this forum as well as ADV riders.
    http://forums.bmwmoa.org/showthread....ectrical-issue
    http://m583.photobucket.com/albums/G...%20Fuse%20Mod/
    http://advrider.com/forums/showthread.php?t=665648
    FYI: the F650's have unfused circuits as well, I have redone & fused the harness on one of those as well.
    Ufda happens..........
    Aug 2012
    GSAddict -
    Thanks for the response and links. I had a short in the headlamp circuit caused by a self-inflected rookie mistake - a lamp wire got pinched when I reinstalled the tachometer into the instrument housing. Fusing the headlamp and ignition switch is a worthwhile project.
    Ken S
    03 R1150RT
    GSAddict -
    You are most welcome.
    Just about every Japanese bike I have worked on has had the headlights fused.
    Just about every GERMAN vehicle you'll encounter--car or bike--will NOT have a fused headlight. Since Bosch essentially invented automotive electrics I'd vote posters here not qualified to call this stupid.
    Perhaps so, but perfected by Lucas Electric.
    Mike Marr
    I have 36 years in Industrial electrics and process controls with lots of marine and auto/motorcycle work.
    Unfused wiring IS stupid.
    I have seen the results time and time again.
    Just to save $,02
    BTW: Audi, BMW and VW DO fuse their headlight circuits. Newer models that don't show fuses have electronic circuit protection. This includes the R1200 hexhead bikes.
    Florida & Massachusetts
    See the fuses for high and low beam circuit on the 2004 R1150RT.
    http://www.mac-pac.org/wp-content/up...agram-V1_1.pdf
    Fuse 8 Low Beam
    Fuse 9 High Beam
    Tested and confirmed on my motorcycle.
    RB
