Results 1 to 5 of 5
Thread: mono shock front wheel bearings
    Total Freak mikegates's Avatar
    Jul 2006
    Eagle.wi
    going to re tire the Rt (95), I have the sealed front bearings, I have a puller, got the bearings. Snowbum says to heat the hub. are these wheels painted? will 250 degrees burn the paint off?
    95 R100Rt, 07 650 GS
    Mike
    Eagle, wi
    "He's gone and nothin gone bring him back"
    Luddite Looney wecm31's Avatar
    Jun 2009
    Eganville, Ontario
    Hey Mike...No answers,just questions.
    I too have the sealed front wheel bearings and have done nada to them in the ~15 years/100k miles I have
    had the bike.
    Are yours starting to feel notchy or otherwise worn? Or is this a premptive replacement??
    Gerald P
    The last thing I want to be is just like everyone else...
    1985 R80RT
    1969 Sport Fury Convertible
    Jul 2006
    Eagle.wi
    just something to do. After jumping it like a willys in four wheel drive, and using the left handed monkey wrench thought it was time.
    Mike
    Eagle, wi
    the heat spec in the repair manual won't harm the paint using a heat gun. Be very careful using (or don't use) a torch. Go slow, apply heat with the gun moving continuously.
    I insert and tighten the bearing puller so it is applying some pressure, then heat the hub. As soon as it is hot enough you will hear a slight creek as the pressure moves the bearing a little - then use the puller to pull it out.
    Jun 2009
    Eganville, Ontario
    Cool
    Quote Originally Posted by mikegates View Post
    ...and get back to work, if you have any sense
    Gerald P
    1985 R80RT
