Results 1 to 3 of 3
Thread: Kenwod TK 3101 Programming Help Needed
    North Georgia Mountains
    We have 3 Kenwood TK 3101 (obsolete, no longer made) radios we use with the Autocoms. Good radios. There is a really cumbersome way to program privacy sub-channels onto the regular channels (I could suffer through that) using the radios directly, but I understand that PC software does it a lot easier. Also...
    Channels 1-7 are FRS and are (supposedly) factory-set to transmit at 0.5 watts (FRS max), while channels 8-15 are GMRS and can transmit at 2 watts. We've experimented, and our range on channel 3 is about 0.7 miles, and our range on channel 15 (GMRS) is the same, so it seems that our radios seem to be programmed to transmit at 0.5 watts regardless of FRS or GMRS. I've heard that the software can change that.
    The software only runs in DOS, not windows, and requires a serial cable to the Kenwood (not UBS). I see I can get a serial cable on Ebay, and the software seems to be available, but I don't think I have any PCs that can run DOS. Maybe my old PC with Windows XP can run a DOS program under 'RUN,' dunno. My local geeks could probably figure out how to run something on DOS.
    Another factor: I an going to use battery-eliminators instead of the TK 3101 battery, use bike power, either through the Autocom, if I can figure out the wiring (real, REAL PITA!) or add an extra 12v bike power plug to run the battery eliminators. I have heard various advice that he Kenwoods cut transmit power from 2 watts to 1 watt when battery eliminators are use, and also that they WILL transmit at the full 2 watts with the battery eliminator. The software is supposed to offer selections to do this, dunno.
    Does anyone know of a knowledgeable Kenwood tech with the software and brains to set our radios up to have privacy sub-channels and transmit at 2 watts on the GMRS channels 8-15? Willing to pay a service fee.
    Any other advice?
    Roger Wiles
    roger@rogerwiles.com
    www.rogerwiles.com
    706.897.8266 24/7 Wireless
    I'm an Autocom dealer and my Kenwood supplier can program the radios for you. Please email me off forum for all of that information or see us at the rally with AUTOCOM DIRECT!
    Lisa Malachowsky
    lisa@divenrideadventures.com
    Lisa Malachowsky
    Board of Directors
    2014 BMW R1200GSW-L / 2011 Suzuki Burgman
    http://www.divenrideadventures.com
    Kenwood
    Will look for you in Salem TY
    Roger Wiles
    www.rogerwiles.com
