Results 1 to 15 of 24
Thread: testing alternator--battery dead
    aapasquale
    Aug 2011
    Sag Harbor, New York
    Hi All;
    My Odyssy battery which has been working very well (until today), seems to have given up the ghost after a short life of 8 months--the only inkling of this was alternate flashing of ABS lights the day before--just ran the bike a few minutes, shut it off and powered up again and all was good--the alternator light did not come on at all except at start-up which is usual--put her to sleep at night and morning was pretty flat--almost nothing--certainly not enough to turn it over--There seemed to be more than adequate juice until, well, there wasn't!!--I have put a good 12,000+ miles on this battery--
    it's a 1994 R1100RS--The battery will not take a charge at all now!--any thoughts?
    Is there a test I could run to see if alternator is functioning properly?
    Thanks,
    Tony
    Quote Originally Posted by aapasquale View Post
    Thanks,
    Tony
    The battery won't take a charge from what source?
    Bike
    Tender
    Regular battery charger
    A quick test of the bike charging system is simply to measure voltage at the battery with the bike running, just over 14V is good.
    You'll need a charged battery to start the bike of course and you need to make sure it won't become disconnected when the bike is running.
    I just had to add that last in case you try this with a battery temporarily rigged up with jumper cables.
    Mike Marr
    I love my Odyssey battery.
    Frankly it is more likely the alternator failed.
    ditto motoradmike
    I think it should kick up 14V even at idle. Certainly it should at anything over 3000 rpm. Put a fan in front of the bike though.
    If that reveals a lower voltage than expected, separate the two components of the system and test separately.
    Charge the battery with an external source to be sure it didn't just die.
    Even an AGM battery will not tolerate complete discharge to zero for very long.
    If memory serves it should charge up to something like 13.8V when healthy.
    I don't think it is possible to vibrate or shock the mil-spec battery hard enough to hurt it and not damage the rest of the bike.
    (just sayin')
    It is an automotive-style alternator.
    If you are willing to pull the alternator you can take it to Autozone where they have a machine that will spin it and produce numbers and a pass/fail assessment. I have not done this for an oilhead, and getting the part off of a car is much easier.
    I bought and use a little Battery Tender on mine. The Motronic and the clock are really "on" all the time, and draw a small amount of power even with the machine sitting idle.
    Quote Originally Posted by scott.lambert View Post
    ditto motoradmike
    (just sayin')
    There are a number of issues that can cause a problem of this nature. However, batteries fail far more often then charging system components. You MUST know with CERTAINTY if the battery is good or bad. Everything else is a waste of time if the battery is bad.
    People will commonly state that something is too new to have failed. But anything that comes with a warranty/guarantee is telling you up front the company is not perfect and they are willing to do something for products that fail too soon. Start your diagnostic trail by knowing with certainty the condition of the battery. If it's good you look elsewhere. If it's bad hold the presses until you have a known working battery.
    Smile
    Quote Originally Posted by billy walker View Post
    I do agree with this. I was just bragging on the Odyssey battery.
    The battery is certainly easier to get to; in effect BMW agrees with the statement as well.
    Whenever it takes an R&R to even diagnose, I always start with cheapest/easiest.
    Speaking of which: This may turn out to be a loose connection.
    The Odyssey (PC680?) has to have these L-shaped brass adapters for the cables to reach,
    so there are more surfaces to be dirty and more nuts to be loose.
    Of note, Exide Technologies, the supplier of many of BMW's batteries filed for bankruptcy a few days ago.
    http://www.bloomberg.com/news/2013-0...-delaware.html
    My point would be that as mentioned, without a good battery, reasonably charged, alternator tests tend to be meaningless and often misleading. With a discharged or faulty battery in the system and connected, voltage readings are almost always lower than they would be with a sound battery. It is thus easy to conclude that there is a problem with the alternator when in fact it is a marginal battery, or even just an OK battery that is low on charge.
    This can be an expensive conclusion if your source for the alternator won't take it back when you discover that the new alternator didn't cure the problem. Other than initial crude checks I wouldn't even attempt to troubleshoot a charging system unless I was positive that there was a sound battery in the system.
    DBLUPPR snookers's Avatar
    Jul 2010
    Niagara Region
    Thought I might chime in and add this little tidbit to the discussion...................A while back I mentioned in the Oilhead section that I wanted to swap out the incandescent lamps in the dash of my 1100RT with LED's since many of them were burnt out anyway. I was informed by another member that there is a 4watt lamp in the dash which is actually a part of the charging circuit. If this bulb was burnt out or swapped with a lower voltage consuming LED the charging system would not function. Just a thought....but when you turn the ignition key to the on/start position, you should see a red light showing a battery symbol.......if not.....maybe this is the culprit?
    2000 R1100RT
    Niagara BMW Riders #298
    BMWMCO #45
    Chapter 11, restructuring. It may mean something short or long term, or maybe not. No need to panic yet. Their biggest current problem is the high price of recycled lead which makes up 40% of their cost of goods sold. Then the republic of california shut down their primary lead recycling source.
    aapasquale
    Aug 2011
    Quote Originally Posted by snookers View Post
    Thanks for the thought--the red light with battery symbol DOES come on with ignition switched on
    Tony
    aapasquale
    Aug 2011
    I've ordered a replacement battery. We'll see how this story progresses. By the way, I should have added from the start that a week before this happened I drove to Americade (300 miles) and drove back back in a 6 hour deluge. The bike seemed to be not affected at all for an entire week after this except for what I mentioned previously.
    Tony
    Tony
    Reading the first 2 sentences seems to imply you have not verified the battery is bad?
    Jun 2005
    Green Bay, WI
    I rebuilt the alternator in my 94RS at 125,000, because the nose bearing was making noise. I had another low miles alternator given to me by a local BMW shop to use for parts. I compared the brush wear in my hi-miles alternator to the brushes in the low0miles alternator and was surprised to see the hi-miles alternator still had over 1/2 the brush life in them. My bet is that unless the alternator develops a failed rectifier/regulator, the brushes should be good for at least 200,000 miles.
    aapasquale
    Aug 2011
    I've had the battery on a charger for four days solid and it hasn't even begun to take a charge-I think I can
    safely assume battery is dead! Tony
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Tony,
    It'd seem so...but it isn't necessarily true: some chargers won't charge a connected battery if the charger doesn't see some juice in that battery. That is, it will recharge a partially-charged or low battery, but won't charge one that's completely discharged. What kind of charger are you using?
    David Brick
    Santa Cruz CA
    2007 R1200R
