Results 1 to 15 of 17
Thread: 03' RT Rear Wheel Removal
    Aug 2012
    Farmington Hills, MI
    Are there any tricks to removing the rear wheel on a 03' RT? With bike on center stand, I had a difficult time getting the wheel/tire assembly between the muffler and the swing arm inner pivot bolt head.
    Ken S
    03 R1150RT
    No "tricks" in your owners manual? Like remove the muffler first?
    On the Road fireguy's Avatar
    Oct 2010
    Federal Way, WA
    You might try deflating the tire and 'wiggle' it out. It worked for me. Make sure you secure the center stand to the front wheel with a strap first. getting it back in is the same. re-inflate the tire and you're good to go. Also try loosening the muffler mount.
    Gerry
    SE Wisconsin
    You can loosen the muffler at both ends, deflate the tire, or just wiggle and scratch up the rim...
    Registered User selyab's Avatar
    Sep 2009
    PNW
    You don't remove the muffler on this one.
    Loosen the knobs found in the tailcone assembly and the rear fender sides out towards the back of the bike. The wheel can then be removed without interference. Like someone else said, check your rider manual.
    Mar 2007
    15 M. E. Tampa
    Removiing the rear wheel from both my RS and my RT takes a bit of oooommmmph. I roll the wheel back until it jams up against the muffler, then cock the rear of the wheel to the left to clear the fender. Then just pull and wiggle that mutha out. It doesn't seem to want to come out, but it does. It goes in a lot easier than it comes out.
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    With the PR2's I have to let air out of the tire and it's still tight. Muffler installed, HF table lift with rear plate removed. I believe it depends on the profile of the tire.
    Registered User amtoro's Avatar
    Jun 2012
    Atlanta, GA
    +1 on deflating the tire; that is how I remove mine.
    also, deflate it to about 5-10 psi before mounting it and then inflate to the proper pressure (ask someone to hold the bike from the front while mounting it as you may push the bike forward and knock it off the center stand).
    '04 R1150 RT
    A one sided swing arm and a wheel that won't come off.
    May I be the first to say UNBELIEVEABLE!
    No longer a member here
    Quote Originally Posted by GKman View Post
    That's why those who really had a reason for a single sided swingarm, designed an under-seat exhaust.
    Well, gee, the official service manual says remove the muffler first.
    This is still the case with Hexheads and Camheads.
    It's just a step in the process--why be so negative? It's only difficult when you don't follow directions and trying to get the rear wheel off without removing the muffler is not following directions.
    On my old Airhead I often removed the front wheel first to make getting the rear wheel off easier. Oh, and I had to remove the left muffler, too ... mostly I think because of Koni shocks.
    Vancouver, B.C. Canada
    Actually lkchris is absolutely correct. I had to check because I've done this a lot and thought what the heck is he talking about?
    Instructions below pasted from the factory manual:
    [RS/R/RT] Removing and installing
    rear wheel (cast alloy)
    Removing rear wheel
    ?[RS] Remove number plate carrier.
    ?[RS/ABS] Detach muffler (silencer) mount/press
    muffler outwards/carefully remove the rear wheel.
    Now that said I've removed the rear wheel on both 1100RTs I've owned at least a dozen times and never had to remove the muffler to do it. Yeah, it's a little tight coming out and you have to wiggle the wheel back a forth a bit but if you are using the specified 160/60-18 tires, they come out (and go back in) without great difficulty.
    well, gee, the official service manual says remove the muffler first.
    This is still the case with hexheads and camheads.
    On my old airhead i often removed the front wheel first to make getting the rear wheel off easier. Oh, and i had to remove the left muffler, too ... Mostly i think because of koni shocks.
    unbelieveable!
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    unbelieveable!
    Try changing the rear on a GL1800 Goldwing.
    Easiest way is to lay the behemoth on its side on the grass! Quite a picture.
    Ufda happens..........
    unbelieveable!
    Uninformed!
