Results 1 to 7 of 7
Thread: 2009 r1200 gsa intermitting start
    Has any body had trouble with an intermitting or delay in the ability to start YOUR R1200GSA WHEN you turn on switch, sometimes it takes up to 10 seconds or more before you can start .. and when coming up through the gears sometimes the whole machine just shuts down momentary from 3 to 5 seconds and yellow caution light comes on, then it will on its own just fire back up and run fine .. this may not happen every time you ride ? it may only do it every 1000 or 1500 miles.. and it may do it 2 or three times on one ride !!I have had it to dealer and put on computer no answer . other than to tell me it'll have to quit completely before they can find, this has been on going for two years HELP PLEASE !!! tHANKS
    r1200 gsa 2009 intermitting start
    Has any body experienced a 3 to 10 second or sometimes even longer wait before any power is sent to controls so you can start bike ? also sometimes while shifting up through the gears it just shut itself down, any where from 3 to 10 seconds again this does not occur everytime I ride sometimes it want do this for several thousand miles ! had it to bmw dealer and put on computer nothing !! said it will have to stop completely Help PLEASE
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    Well, two things come to mind.
    1. Original battery? BMWs are very finicky when it comes to voltage.
    2. My better guess, gear selection sensor and/or side stand switch. If it isn't correctly sensing the side stand being up, it will kill the engine when it knows you are in gear. Or even weak spring so it is bouncing down, or maybe your boot bumping the switch or side stand?
    What is interesting though is that for low voltage and sensor failure, I think those show as old faults in my GS-911 so the BMW shop should have found old fault codes. For the weak spring/stand accidentally moving, that wouldn't read as an error in the computer.
    Anyway, those are my wild guesses.
    Could even be dirty kill switch too, I guess.
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA
    Hard Starting
    After they took care of the recall items I had problems with hard starting.They replaced the battery and one injector.They delivered the bike and the exact thing happened again and we got into it pretty good.They changed the second injector and the problem was solved.At the time it was under warrantee.
    Jun 2007
    Portsmouth, NH
    Are the battery terminals tight?
    Spring Lake NJ, USA
    Mod-Action
    Two threads have been merged into one..
    Quote Originally Posted by Woodbutcher View Post
    Replaced battery, ,Ihave tried to shake the side stand , while riding nothing ,have also tried to move around kill switch seems to be in good shape, only kills in when it is switched all way in the off position .what gets me is the delay in the start when I turn switch, sometimes it will start instantly, and other times may have to wait 3 to 10 seconds before
    any thing will happen
