Quote Originally Posted by lmo1131 View Post
Duane Ausherman has a good write up on the main switch. -> http://w6rec.com/duane/bmw/ignkeys/
this is the front view of the switch in the "OFF" position
this is the switch in the "On" position - hard to see due to lighting
If the contacts are touching when the key is out check to see if the light contact spring(s) have gotten bent. It happens. More often than not it is the heavy brass contact that is bent; open, or close, the gap (between the light spring contact and the heavy brass one) by carefully bending it. It's definitely a trial-and-error operation.
Photos (that I altered) are from Duane Ausherman's site
Very visual and understandable - thanks again, Lew.
