Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Thread: Motorcycle Maintenace Costs versus Automobile
    Just a topic for conversation that's been running thru my mind lately. I ride 2012 R1200 RT and love both the bike and riding in general. I ride quite a few miles, it's due for it's 30K service and is 14 months old.
    My thoughts are why does it cost so much for maintenance and why do things on a motorcycle wear out faster than an automobile. As a comparision, I have a 2009 Honda CRV with just over 85K miles on it. It's got the original brakes, has never had a tune up, outside of a $40 oil & filter change every 5K miles or so, has been perfect.
    My RT has burned out 1 headlight bulb, had the front brakes replaced, and now the 30K service is going to require flushing the brake system, changing all the fluids, and misc other stuff to a tune of nearly $800. BMW supposedly makes the best bike in the world, I'm just wondering why the bike is so much more expensive than my car usage, I ride many of the same roads I drive and treat it with the same care, probably more.
    I'm not complaining about the bike or my dealer, just thought some of you more experienced riders might share you're thoughts. Are we all suckers or do bikes really need that much more maintenance and should it cost as much as it does? I know I need to learn to do some of my old maintenance and I'm working towards that, especially once the warranty expires in another 6K. Your thoughts please.
    IBA Number 49673
    Moore OK
    http://lngrdr.blogspot.com/
    Oct 2003
    Even a touring motorcycle like the the RT is a high performance vehicle compared to your Honda car. Everything is built lighter for better performance. Think about the tires you probably buy every 6-10,000 miles for your bike. The tread is much thinner and softer than the tires you buy for your car. The shocks are much more finely tuned and wear out sooner (and you'll feel your bike wallowing on old shocks a lot sooner than you'll feel it in your car.)
    BTW, you should really change the brake fluid in your Honda. Although there's a lot more brake fluid in it than in your RT, with just a similarly sized opening for moisture to creep in, you should still change it more often than you are.
    http://darryl.crafty-fox.com
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Darryl's right about tires, but economies of scale also play a part: bike parts generally (or at least often) are more expensive than similar auto parts because there are a lot fewer bikes than cars.
    And I agree with him about the desirability of brake fluid changes. Brake fluid is hygroscopic - it absorbs water. Moisture is absorbed and will eventually find its way to the lowest part of the brake system. The result is corrosion pitting the piston bores in the calipers, which abrades and cuts the rubber piston seals. Changing the car's fluid regularly, say every four years, significantly reduces the chance that this will occur. Because the volume of the bike's hydraulic system is smaller than that of the car, and its reservoir more directly vulnerable to the atmosphere, I change the bike's brake fluid every two years.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Registered User natrab's Avatar
    Sep 2012
    Oakley, CA
    It's kind of a bad comparison as well since you appear to be maintaining the suggested maintenance intervals on your BMW but not on your Honda. How much would all of your tune-ups and major services cost for your car? I know for my Tacoma having a dealer to a major service is still in the $600-800 range along with oil changes every 3k. I usually do most of the service myself and spend about $200 having my mechanic finish up the harder stuff.
    The nicest thing about the BMWs is how easy it is to do your own work. I've spent less than $200 doing two major services myself along with $300 for new tires. Not much for 15,000 miles of enjoyment. Do you enjoy all 15,000 miles spent in your car?
    2013 R1200RT 90th - "Tyr" - 65k - Purchased 12/13/2013 brand new!
    2011 R1200RT-P - "Ursula" - 18k - Purchased on 1/30/2016 at 13k miles
    2007 R1200S - "Sexy Beast" - 28k - sold
    2006 R1200RT "Wōden" - 84k - sold
    Sep 2012
    Lansing, Kansas
    Quote Originally Posted by natrab View Post
    I do ALL the recommended svc on both my cars (matching Ford Escapes) at the dealership and have always done so. Both have been perfect for 100K+ miles on each vehicle. And they still have been cheaper to maintain than my motorcycles, both Japanese and German brands. For all the reasons cited by other posters, bikes are more expensive and will always be more expensive than cars. Plus no one has mentioned the fuel mileage issue--bikes that get as many as 50 mpg are sluggards compared to cars that get way more "passenger miles" (weighs ten times more but carries up to four pax and still gets 25-30 mpg).
    But I am NOT complaining. My bike is more fun to get around on and it gives me what I consider a better life style. I don't know anyone who rides a motorcycle because it saves money. Some folks claim that's why they ride, but I don't believe it is never about money.
    Royce
    On the coast of Kansas
    2012 F800ST
    Sep 2012
    Oakley, CA
    In the long run, cars will be cheaper to maintain, but I think it's not a very big difference if you do your own work on the bike (which is way easier to do than on a car). I'd rather pay someone $30 to change the oil on my Tacoma than do it myself.
    On my BMW, I spend about $200 on parts every 12k miles and if I changed the tires at that interval add another $300. So $500 per 12k on the bike.
    In my particular situation, I commute about 80 miles a day 4 days a week by bike. On my bike I get a little over double the mileage of my truck, which means that in 12,000 miles, I'll have saved around $1200 over driving my truck. Factor in my bike payment is $144 a month along with the $500 per 12k mileage, my bike is more than paid for with my commute.
    Yes, I could by a little commuter car to haul me to work and back, but not only would it still get lower gas mileage, it would set me back the money to buy it and slow my commute down dramatically.
    Albuquerque, NM
    Quote Originally Posted by royce View Post
    Motorcycles are toys.
    Compare to Porsche, Ferrari, etc.
    Kent Christensen
    21482
    Braintree, MA
    Bike costs more, I don't farkle my cage...
    -Tom (KA1TOX)
    RK Ryder
    London, Ontario
    I always have keep very detailed records of the costs for our vehicles. When I got my K, I began to do the same record keeping as for the cars. After a short while, I simply filed my bike maintenance costs into a binder but soon stopped tallying the costs. It was evident that I didn't wish to know the amount that the bike required. Having said that, since then I now do my own services (not repairs) on the bikes. A 20,000 km dealer service used to run between $1000-$1100. I can do the same for a little under $200, unless brake pads are required. It may take me a day and a half or so, not having a mechanical background, but, I am retired, so I have the time.
    Paul
    Knights of the Roundel #333
    Enjoy The Ride saddleman's Avatar
    Apr 2009
    Huntersville N.C.
    Not for all of us. For me it is just transportation & my only transportation.
    Dave Selvig
    2004 Black LT
    2000 Canyon Red LT
    Apr 2009
    Huntersville N.C.
    I ride about 35,000 miles a year give or take 5,000 miles & the last time I kept every receipt for one year it added up to just over 10 cents a mile. I do all of my own maintenance & repair and I mount my own tires. That year included a new GPS & radio purchase.
    Dave Selvig
    2004 Black LT
    2000 Canyon Red LT
    Good points, I don't enjoy any miles in my car, probably why I don't spend the money on suggested maintenance for it. Thought I'd get a few opinions from you guys, thanks for the replies, I guess I'll just pay to play and learn more about doing some of my own maintenance. 30k, plus annual, plus a new set of PR3's next week, dealer's quote of about $1100 for it.
    IBA Number 49673
    Moore OK
    No longer a member here
    Apr 2006
    Quote Originally Posted by LngRdr View Post
    BMW supposedly makes the best bike in the world, .
    Did you read this on the internet?
    Polarbear Polarbear's Avatar
    Clovis,CA
    My costs, very small:)
    I've owned BMWs for 42 years, continually and IF I had never learned to work on 'em, never would have been able to continue. The dealers are fine friends of mine too, just I cannot go there except to buy bikes. My service is entirely my thing, from the 600m initial dealer one I pay for. I like it this way, always have enjoyed tinkering my own machines. Saved me gobs of dollars and so much wiser for it, knowing what's under me so much better. The bikes are NOT so expensive in many ways and very reliable over all, mine anyways. I've got an Airhead here with 388000m, almost all original, not rebuilt(even the valves, unheard of)!!!! I do not think the new ones by BMW are Airheads, not likely at all to last like this without issues, but my current GSA1200 is almost at 100000m now and very good still. I see MOORE,OK, your address. Man, y'all been thru Hell, wish ya well. Been watching closely on TV here, the middle USA gets hammered. Stay safe. Randy
    Albuquerque, NM
    BMW supposedly makes the best bike in the world ...
    Lots of folks might think the Bugatti Veryon the world's best car but its tires only last 7K miles and cost $15,000 to replace.
    Does that detract from anything?
    I agree with the quote, save for "supposedly."
    (Oh, it could be the other way around, i.e. 15K miles, $7K.)
    Kent Christensen
    21482
