Results 1 to 8 of 8
Thread: '03 K1200 LT Center stand Question
Hybrid View
    LEAD HAND HUDSON hudsonrn's Avatar
    Jul 2010
    FORT MYERS, FLORIDA
    I have a2003 K1200 LT. Has anyone figured out a trick to getting it up on the center stand without getting a hernia? Thanks.
    SCPerra
    Jun 2011
    South Central CT
    Smile Getting the beast on center stand
    Quote Originally Posted by JHUDSON View Post
    Push the big girl onto a block 2 by 4 hold with front brake she will almost roll back and right up on the center stand, when you release the brake.
    Dec 2004
    Winnebago, Il
    Make sure the bike is in neutral, grab the hand grip located under the front of the passenger seat with your right hand. Press down on the center stand arm with your right foot while bringing the bike up to a vertical position so that both feet of the center stand are holding the bike vertical. Once the bike is vertical and being balanced on the feet of the center stand apply more of weight to the side stand arm while gently lifting the bike with your right hand. It will walk right up on the center stand. Trying to lift with brute force does not work to well.
    Roy G.
    85 K100RT Ol Ruby "Gone but not forgotten"
    02 K1200LTC Hoss "Wrecked on 9/21/14"
    12 R1200RT
    Quote Originally Posted by roy View Post
    more of weight to the side stand arm while gently lifting the bike with your right hand....I believe you meant [center stand] arm?
    Dec 2004
    Winnebago, Il
    Quote Originally Posted by 71243 View Post
    yup, sure did and good catch on your part.
    thanks
    Roy
    Roy G.
    12 R1200RT
    Hitch hiking on Roy
    Take what Roy has said and keep in mind: you must get the bike on both pads of the center stand, place the ball of your foot just a touch ahead of the stands foot pad
    hold the bike tight and stand up with your left foot leaving the ground. The bike should move back toward the right and plop right on the stand. Soft shoes will cause a disaster as well as any
    other surface that is not hard. Once you master this technique it will seem second nature.
    73 Jerry
