Results 1 to 13 of 13
Thread: Seal Swell ??? BRAKE FLUID ???
    North Georgia Mountains
    I see my GS is weeping onto the shelf at the rear, rear main seal is 3 years old, latest version at the time. Not a big deal, it can weep until the cows come home or I buy enuff beer to change it. Wuz at the auto parts, and just for giggles, asked them if they had any magic juice that might swell up a seal. They did, fifteen bucks, BUT...
    ...the counter guys said, "For three quarts of oil, put in about half an ounce of brake fluid. Works like a charm."
    Anyone ever try this? Can it do any harm elsewhere?
    Anyone ever found any other magic juice that might swell up a seal, assuming it hasn't torn or been damaged?
    Roger Wiles
    roger@rogerwiles.com
    www.rogerwiles.com
    706.897.8266 24/7 Wireless
    Mansfield,MA
    I would try the Lucas additive. I have it in stock for wheel hubs, transmissions, steering, engine oil and hydraulic fluid. I have had enough good results that recommend that the Lucas problems are worth the try. OM
    Mod Squad
    2009 F800GS 1994 TW200
    Seal
    Thanx. Hey I see you have a TW! Cool little GS, isn't it. We have one, originally intended as TLN's (The Lovely Norma) Forest Service Road GS, but I use it to scout unknown roads - hey, if it breaks, I can carry it out of the woods...
    What is the name of the Lucas stuff? If you sell it, how much to send me some?
    Roger Wiles
    www.rogerwiles.com
    What gear oil are you using? Most of the gear oils today already have those types of additives. I suspect the issue is likely seal wear if it got put back on to the same rough spot on the end of the crank.
    Edit: As Kent points, out I was on the wrong side of the oil situation! Doh! But even so, same situation with oil additives...they're designed to work well with seals and keep them pliable and in good shape. Shouldn't really need to doctor the chemistry...IMO.
    Mansfield,MA
    This is what I'd try in your case http://www.lucasoil.com/products/dis...l%20Stabilizer
    and no- I don't sell it, just have enough experience with it so as I can recommend it. It's available at most any auto parts store.
    As far as the TW, yeah it's a hoot. Me and a friend of mine spent part of today with the carb apart doing a "shim job" so it will run without the choke.
    Let us know how you make out.
    Gary
    Mod Squad
    Lucas?
    I have been a fan of Lucas products for years in my car, and now use it in my motorcycle.
    However, has anyone looked into the difference between what they call their "Oil Stabilizer" and their product called "Oil additive that helps stop leaks."
    Are these the same but just marketed with a different purpose? Or are they, in fact, actually different products?
    Rear mail seal doesn't see gear oil, just engine oil.
    Mansfield,MA
    Quote Originally Posted by JIMMYLEE View Post
    Had the same thought myself I just keep pushin' on.
    Mod Squad
    Dec 2004
    Winnebago, Il
    Quote Originally Posted by WooDmEn View Post
    Dot 3 or 4 brake fluid will potentially do more than soften the seal material. Depending on what the seal material is it may actually make it dissolve into a puddle of goo.
    Whether or not a 1/2 ounce for 3 quarts of oil would be enough volume to do this I do not know.
    Roy G.
    85 K100RT Ol Ruby "Gone but not forgotten"
    02 K1200LTC Hoss "Wrecked on 9/21/14"
    12 R1200RT
    If you have the recent (brown PFTE) rear main seal, it won't be affected by brake fluid.
    Must have been a really old guy at the parts counter. That's one not heard very often anymore. I've seen it work but not anytime recently. The new materials used these days I'd think it would not work or even cause damage so I would not do brake fluid to try and curtail a leak. Or more of what looks like a weeping.
    And now that I think of it, it was always an automatic transmission leak that the brake fluid was for. I don't remember it for engine seals.
    FWIW, I don't think I've ever had a counter guy say anything even remotely valuable or accurate.
    spencer
    "FWIW, I don't think I've ever had a counter guy say anything even remotely valuable"
    Dude, you need to visit Hermy's BMW
