Results 1 to 5 of 5
Thread: do I buy a fuel pressure regulator 1990 K1
    Registered User E.L. Buff's Avatar
    Nov 2009
    Elmer New Jersey
    Replaced everything in fuel system been setting for years with gas in tank
    i forgot to order a fuel pressure regulator , now i have all the parts do i
    reuse the old regulator or wait and get new one , do they have parts inside
    that will go bad with gas setting in them . I think i know the answer but need to be sure
    thanks ernie
    RK Ryder
    London, Ontario
    Just remember that there is a lot of stuff to remove if you have to replace the fuel pressure regulator later. If you already have everything apart, it may be more expedient to replace it at this time. My K100's needed replacing at 89,000 miles.
    Paul
    Knights of the Roundel #333
    At $151, I'd say no. Once you get the fuel hoses hooked up, but BEFORE you put the body work back in place, do a fuel pressure test. If it's good, I would not waste the money.
    Nov 2009
    Elmer New Jersey
    Got it all hooked up new fuel lines and vacuum lines some gas in the tank as soon as the pump started hit the starter button again
    and it started right up first time it has been run since 1997 the test gauge read 38 psi it runs good so far so good .
    the ABS break bleeding is another story I think I have it will soon know bleed it with a hand vacuum pump.
    Ernie
    Quote Originally Posted by E.L. Buff View Post
    Ernie
    You just saved yourself $151!
