Results 1 to 6 of 6
Thread: ticking sound, right cylinder
    Jun 2012
    Grosse Pointe Park, MI
    After warm up on my '77 r100, there is a consistent light ticking sound from the right cylinder. Only 18k miles on it and it was completely gone through last year by cert mechanic. Any thoughts?
    What does "completely gone through" mean? Can you say what he did? Did he use a mechanics stethoscope to isolate the exact location of the sound?
    My first thoughts would be: valve clearances, rocker arm up/down movement, head gasket installed backwards.
    Registered User ebeeby's Avatar
    If there is no "slight ticking" from BOTH cylinders of my R75/5 - I'm in trouble.....
    Polarbear Polarbear's Avatar
    Clovis,CA
    Same bike;
    R100'78 here too and its most probably the tappets slightly looser on that one side. NO big deal, as one mentioned already. Its good to hear this. An easy check, however with valve cover off. Randy
    Fenwick, Ontario Canada
    Loud valves are happy valves
    You should check the other side!
    Knights of the Roundel #333
    Pistol Shooter headhog's Avatar
    Jan 2011
    Farmville, VA
    Quote Originally Posted by Darryl Cainey View Post
    I recently acquired a 1994 R100R that was in storage for 7 years. When I heard it run the left cylinder was ticking nicely, but the right was fairly quiet. Checking both cylinders clearance I found the left intake spot on and the exhaust a little tight. The right cylinder, the quiet one, was tight on the exhaust but the intake had almost zero clearance. After adjustment both sides are now ticking like a Swiss watch.
    Tappy is Happy!
    MSF Instructor
    1992 R100GS
    1994 R100R Mystic
    2007 Harley Electra Glide Classic
