Results 1 to 6 of 6
Thread: Help needed with tube connection
    bharvey60
    I have a 98 RT that was dragging a rubber tube. One side of the connector (plastic elbow) was routed around the airbox. Anyone know where each end is supposed to be connected and what purpose this serves. Photos attached. Thanks.
    Albuquerque, NM
    Battery overflow.
    Not used with sealed batteries
    Kent Christensen
    21482
    bharvey60
    I'm guessing this is the original battery overflow? If so, no longer needed since I have a gel battery
    bharvey60
    Thanks for confirming
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    Yes, it's most likely from a past battery. The big clue is the right-angle connector: the fittings on the tank & canister vents are straight (unless the owner teed them together).
    Albuquerque, NM
    English is funny ... if it's flexible it's usually called a hose.
    Guy had a fuel leak over on the R1100S forum and he called it a gas leak.
    Kent Christensen
    21482
