Results 1 to 6 of 6
Thread: Silicone Valve Cover Gaskets?
    Fenwick, Ontario Canada
    Who sells and stocks Silicone Valve Cover Gaskets for Airheads?
    Knights of the Roundel #333
    Administrator 20774's Avatar
    Feb 2004
    Monroe La.
    http://www.realgaskets.com/index.htm
    Real Gasket link above.
    1975 R90/6, 1980 and 1982 R65, !959 TR3A Triumph Car
    Pismo Beach, CA
    ... just don't "wet" them with a swipe of oil before you install them; they tend to squirm around and squish out if you do (both tetch-nikle terms).
    I'm Not having much luck with my silicone pan gasket; still weeps a bit with an occasional drip left on the floor.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Albuquerque, NM
    Here's my silicone gasket experience ...
    The pan gasket is a better solution than OE paper but be sure to loctite the screws
    Valve cover gaskets only useful if head surfaces are imperfect--otherwise they are a PITA compared to OE
    Don't bother with silicone float bowl gaskets as first gasoline contact ruins them
    Kent Christensen
    21482
    Pismo Beach, CA
    Counter to my grain, but a few (?) of those holes are "through holes" and oil makes it's way past the threads ... I've been told. Maybe that's what's happening on my /5. Guess I'll bite the bullet and give it a try.
    My pan OEM pan gasket never leaked until about a year ago. Careful inspection didn't show any surface damage on the pan or the block but I ordered the silicone gasket and my "leak" pretty much went away, although not completely (we're talking a drip or two every few days or so)
    Lew Morris
    1963 Dnepr
