Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 42
Thread: Realistic Tool Kit 2012 R1200RT
    Registered User apexal's Avatar
    Nov 2011
    Dover, NH
    I'm putting together a tool kit for my 2012 RT and looking for suggestions on what to put in the kit. Last year I put together a tool kit for my GS; it's bulky and heavy but I can get away with it because the aluminum side cases are big enough and the GS can better accomodate the weight. I don't want to do the same with the RT, especially since the RT side cases are so much smaller. I'd like to put together a tool kit for the RT that has the basic stuff for roadside repairs and for basic maintenance when I'm away from home. Actually I'd like recommendations for the GS, too, so I can cut down on the size and weight. Thanks in advance for your helpful suggestions.
    Last edited by deilenberger; 06-03-2013 at 03:24 PM. Reason: added year/model to title
    Dover, NH
    2014 BMW R1200GS Racing Red
    1973 BMW R75/5
    Albuquerque, NM
    You'll need a pair of pliers for stop n go tire plugs.
    Kent Christensen
    21482
    Braintree, MA
    Sorry, thought it had something to do with RadioShack...
    The short answer to your question is that I carry all the tools I'd need for jobs I'm willing to do on the side of the road, so my tool kit would be different from yours. Mine weighs about 18 pounds.
    -Tom (KA1TOX)
    May 2007
    Raleigh, NC
    Not to be a smart ass, but the credit card is my main tool (and I'm a 100% work on my bike guy). That being said, I carry:
    A set of torx drivers. It is a combo tool like a swiss army knife but it is torx drivers.
    crescent wrench.
    Combo screwdriver (the kind with multiple blades for one handle).
    Duct tape and wire ties
    Vise grips
    I also carry an antenna ring (for EWS failure) and a spare used fuel pump pressure regulator board. And a tire plugging kit with CO2 (big CO2).
    I figure if I need something beyond that, I will get it from the home depot, etc., on the road.
    Rob C. , Raleigh, NC
    '10 R12RT, R90/6
    2007 CBR600RR & 09 V-Star
    Suzuki DR 350
    na1g
    May 2011
    Greater Bahstin, Massachusetts
    I replaced the BMW tools with quality Torx sockets and a socket handle. To break loose those bolts for wheel removal I added a 12" long piece of steel tubing (EMT) as an extension for the socket handle. Then added a couple of things I needed for routine maintenance etc, a tire plug kit, and I'm good to go. Some Iron Butt riders carry an entire final drive but that's a bit excessive for me. My credit card and BMW Roadside assistance card could be my most valuable tools.
    Cool avatar, apexal. The moon is still up there but not the Old Man, sad to say.
    pete
    2011 R12RT
    No longer a member here
    Apr 2006
    A wrench for the lugnuts on the rear wheel.
    Registered User dmftoy1's Avatar
    Mar 2012
    Lexington, IL
    Stop-n-go plug kit and mini compressor and Cruz BMW tool roll have been good for me. I've replaced selective tools after every trip if I found existing one lacking. (Eg. Fenix led flashlight. Bigger set if vice grips, etc.)
    That set of tools, some stout zip ties and duct tape and I'm set.
    Registered User tuckerman's Avatar
    Aug 2012
    Poconos, PA
    Quote Originally Posted by dmftoy1 View Post
    +1
    J.R., 2012 RT
    MOA #186976
    IBA #42334
    Mar 2005
    Clinton, TN
    GS not RT but
    good for thought: click
    Dan
    2010 R1200GSA
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Quote Originally Posted by tommcgee View Post
    The short answer to your question is that I carry all the tools I'd need for jobs I'm willing to do on the side of the road...
    Exactly right.
    Used to be the OEM toolkit was good for just about anything. Those days are gone.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Polarbear Polarbear's Avatar
    Clovis,CA
    Airhead tool s:)
    My old /7 R100 has a great tool kit and many tools cross over. Not all have an older Airhead around but that's a great idea. Access it. So many multi purpose tools exist now, so shop for those, eliminate weight this way. I carry a dual sided wratchet, multi unit as example for my sockets and torx stuff. Zip ties are one few think of, I carry many. E.Tape a must. Mini knife of some sort and these are multi tool oriented. Hand cleaner in a tube, as toothpaste like tube. Those blue paper shop towels are in my bag, folded small and flat at bottom of bag. A generic plug kit found anywhere in an auto parts store (about 5$), with sticky snakes and fresh rudder cement. If ya run tubes, I highly recommend a small bottle of Slime for tubes, as it can save you hours along the side of the road. I've done this a few times, works really good, change tube later at a safer locale. My mini compressor. Some are not tools per say I list, but! Multi tools, the more you find the less you carry in weight. NOT a tool, but a horrible day happens when you get broke down and NO water to drink. I always keep water on board. Works for "radiator" too, if ya spring a leak. OH, almost forgot my Volt Meter I always carry on trips. A very tiny one from Radio Shack I've had for years, no bigger than a pack of smokes. I don't smoke. A mini light tester with needle point to E. test is easy to pack and are very tiny too, if ya shop. The ONLY BMW part I pack along is the Ring Key Reader for the "ignition key", as they have failed on many freinds bikes, not mine. Its a day or more ending affair if you have no replacement!!! Cheap enough and it lives on my bike as a new spare and easy to repair alongside road. Randy
    Nov 2011
    Dover, NH
    Some great feedback. Thanks.
    I used to think that a credit card and cell phone was all that I needed. But after a flat tire and a $300 bill to have my bike hualed 125 miles back home I realize that I need to be better prepared. I do carry an Adventure Designs micro tire pump repair kit on both bikes but I'm still not carrying a decent tool kit on the RT. I don't do much work on my bikes nowadays so I'm out of touch with what I really need to carry. So I'll use this feedback to put together a tool kit for the RT and maybe pare down my GS toolkit.
    If anybody is willing, can you post photos of your tool kit? Thanks!
    Dover, NH
    1973 BMW R75/5
    Santa Cruz CA
    Photo below; stuff marked with asterisks was in the OEM toolkit.
    3/8" ratchet handle
    screwdriver handle*
    flat screwdriver blade* and screwdriver extension* and Torx screwdriver bit*
    1" PVC, 6" long 10mm x 13mm wrench T40 wrench*
    14mm wrench
    10mm x 12mm wrench
    3/8" extension, 6" long
    oil filler tool T50 bit T45 bit T30 bit front axle tool 15mm socket hex keys: 2, 3, 4, 5, 6mm
    misc zipties and a small wire nut left over from the new brake LED install
    Rolled in the OEM wrapper, it's bigger than stock but fits in the under-seat recess.
    Stored outside the tool pouch and under the seat: small roll of duct tape, spare fuses, nitrile gloves, a few paper towels, air compressor, jumper cables, nylon straps, spare taillight bulb, tire plug kit, tire gauge
    Not shown: small diagonal cutters (they were added later). The metric wrenches and hex keys were left over from some older BMW toolkit, and I just couldn't leave them behind.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Registered User liv2ride's Avatar
    May 2012
    Honolulu, HI
    I took the simple route...
    I bought the Adventure Designs kit specific to the RT. I have not needed any other tool since. I also carry a plug kit and CO2 inflator.
    Scot
    2009 R1200RT beemeup's Avatar
    Portland, Maine
    Tool Kit
    +1 on the Adventure Designs Kit, I use it for all my regular maintenance too. I carry a GS 911, Nealey Tire Repair Kit, Cycle Pump, Spare EWS Ring, and a by pass cable for the fuel pump.
