Results 1 to 3 of 3
Thread: 81 r80gs front brake
    Dec 2004
    Chapel Hill, NC
    after a 5 month sleep my 81 r80gs brake lever touches the grip. Pumping does not help. Solutions?
    Bill Weidner
    Albuquerque, NM
    Rebuild or replace master cylinder.
    Kent Christensen
    21482
    Administrator 20774's Avatar
    Certainly start with a fluid change, but as Kent say, you may have developed rust in the master cylinder which will tear the seals on operation. Try a fresh bleed...if it doesn't hold pressure, then on to the master cylinder overhaul.
