Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: 1999 R1100RT runs bad, need advice.
    Registered User bcusack's Avatar
    Blackstone, Ma
    1999 R1100RT 62K miles. Running beautifully until a fill up and after about a mile or two had some problems, would not idle and had no power to pull hills unless I kept the revs up. Under no load on flat roads seemed to run ok. Got to my destination and it would not start once cooled. Got the bike home and removed all the old gas and put fresh gas in, no difference, I?m now pretty sure the fill up was a coincidence. The fuel pump fires up and pressurizes when the systems is closed and freely pumps fuel through the system and out into a container the few seconds it runs when the key is turned. The plugs are new but the spark looks weak , I replaced the plug wires, the coil measures fine yet I had it stressed tested locally and it works well, pulled the BBS and had a little carbon buildup but not bad. The bike will start by holding the throttle open a bit but runs like crap. I have not adjusted the valves yet but I doubt they would have changed adjustment so suddenly. I have not done a TBS as it is not running well enough to do so but at higher revs the twin max pulls evenly.
    I've been through everything and the only thing that eludes me and I don't think is normal is the weak spark. I get a weak yellow or orange spark from the plugs not a nice white or blue snappy spark like I would expect. The weak spark does seem to change in intensity from cold to warm, somewhat weaker when warm. The spark sometimes is more like static and dances all along the electrode instead of jumping at the gapped end. I'm leaning toward an intermittent HES. The HES was replaced 4 years and 30 k miles ago. I did pull the HES and peeled back the insulation to look for the deteriorated wires I had seen when I replaced it the first time. The wires seem soft and pliable with only the faintest hint of the green corrosion you see around electrical connections. The HES also seems ok by the fact that it causes the injectors to spurt and the plugs to fire. When the HES failed the first time the bike just died. This time the bike starts hard and runs badly. Would the intermittent HES cause the weak spark? I know the HES on these machines are troublesome can they fail after 4 years? Should I be looking for other problems?
    Other info; Two weeks and two tanks of gas before I had trouble I did replace the fuel lines, filter, etc. I opened it again yesterday just to see if I may have messed something up and it all looks ok.
    I do use these forums a lot for help and I do appreciate any help or insight you can give me.
    Feb 2005
    Trinity, NC
    WOW! Did you read my post on another BMW forum? I am in the middle of the exact same issue. First thing I did was check your location to see if you might have used the same gas station as me. Mine is a 2001 R1100RT with 105,000 miles. Same sequence of events. Running great; fill up at the end of my ride, then it won't idle and runs like garbage. I have replaced fuel lines and filter, fresh gas, good plugs. No improvement. My HES has never been replaced and never given a hint of problems - until possibly now.
    I will watch this thread carefully - let's share the fix if either of us gets there first.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Massachusetts
    If either of you has, or can borrow a GS-911, there are a lot of things that can be ruled in or out. The process would be to attach the 911, select all realtime values, the LOG to CSV file. Start the bike, run for 5-10 minutes, examine the data and see what the input sensors are doing. If you get that far and would like it, I'd be happy to have a look at the files.
    RB
    Massachusetts
    And a follow up question, are you watching fuel flow in the return line going back to the tank or in the high pressure line coming from the tank?
    Feb 2005
    Trinity, NC
    Both of our bikes are R1100RTs; I'm not sure how much data the GS-911 can get off of the R11 bike system. I don't have access to a GS-911.
    I am looking at fuel flow at the fuel injector. I have looked at it with the injector pulled out of the throttle body, and also with the fuel line unclipped from the injector. So I have seen fuel flow straight out of the fuel line, and fuel spray from the injector tip when the starter gets cranked.
    Blackstone, Ma
    Thanks Roger,
    In my case it is the return line to the tank, after the fuel distributor. I also get a nice even spray from both injectors.
    Massachusetts
    I always forget that the GS-911 doesn't retrieve and log realtime values for the R1100. Thanks for reminding me. Having one wouldn't help that much now. If you do a search you can find out how to get the Motronic to read out its errors and there's also a TPS cal signal at the diag connector.
    Once you remove the injector from the fuel distribution the pressure is released and even with split hoses I got a pretty good stream of fuel. Injector spray was there but anemic. When you check the fuel flowing in the return line the pump and hoses have to be in good enough condition to force fuel past the 43 psi regulator. I'm not saying for sure that you have a fuel problem, just that you need to look at return flow to judge the system's integrity,
    Jun 2012
    1100 motronic
    I don't remember all the steps, still looking. You short something and it starts pulsing out stored codes.
    I just used an analog voltmeter to detect the pulses...
    Please see pages 71 through 73 of:
    http://ibmwr.org/r-tech/oilheads/R11...ce_2-25-02.pdf
    Attached Files Attached Files
    Blackstone, Ma
    Roger, with what you are saying and what I am seeing I believe I'm ok on the fuel side of the equation. How would you describe "anemic"? Mine sprays a fine mist in a V pattern maybe even conical. Any thoughts on what I feel is a weak spark? Am I chasing gremlins? I will try to pull the codes but I'm concerned they may be corrupt as I've had several components apart at this point, I'm not sure how the system stores codes.
    Thanks again.
    Massachusetts
    Quote Originally Posted by bcusack View Post
    Thanks again.
    I agree it seems as if you are lokay on the fuel side since you are pushing fuel up the return line. It would be good if someone with R1100 HES failure experience could weigh in. It sounds more like that than fuel.
    Massachusetts
    Thanks again.
    I agree it seems as if you are okay on the fuel side since you are pushing fuel up the return line. It would be good if someone with R1100 HES failure experience could weigh in. It sounds more like that than fuel even though you repaired it before.
    Jan 2009
    Hillsborough NC
    My second bike just experienced this. Was so bad I wasn't sure I could get home. Then it would clear up. Periodically it would do repeat this. It was due in for some work at the place that also does my K RS. The first thing that was checked were the battery connections. They were loose. That fixed it. In reading about similar issues, a chaffed wire will sometimes produce a similar result. So check your wiring just to be sure all is solid. The guy that knew this says he also checks that first when a BMW comes in with some reports of sudden stumbling and running very poor.
    Most likely not your issue but still something to remember to check.
    NCS
    03 K 1200RS (Black is Best)
    03 Honda RC51
    74 Honda CB750 K4
    Mansfield,MA
    Mod Squad
    2009 F800GS 1994 TW200
    Feb 2005
    Trinity, NC
    Well, I narrowed my suspect parts down to ignition coil or Hall Effect Sensor. Independently, somebody sent me a message - said that my symptoms (same as yours) sounded like a bad coil. I chased down a few auto web sites with descriptions of bad coil symptoms and except when the coil totally fails, the symptoms of a bad coil are exactly what you and I are experiencing. So, I ordered a replacement coil - should have it in hand middle of the week and I'll report back the results.
    Feb 2005
    Trinity, NC
    For my bike, it wasn't the ignition coil. Too bad because it was so easy to replace and it was fairly inexpensive. So, that left me with the HES - or something really bad in the engine.
    I pulled the HES this morning and like so many others, the wires inside the harness alongside the plate and strain relief area, those wires had brittle insulation which cracked and broke off. I'm clearly not good enough with a soldering iron, so I ordered a new replacement HES. I'll report back after the new HES is installed.
