Results 1 to 3 of 3
Thread: How do I see all threads?
Hybrid View
    Registered User LDB's Avatar
    May 2013
    Houston
    When I am on the "Forum" tab it says there are 8846 threads in the Airhead section but when I click on it it says there are only 4 pages of 25 or 100 threads. I get similar results in other sections but don't recall specific numbers to quote. What do I need to do to see every thread? Thanks.
    Welcome! Everyone is set up with a default number of threads to see. It can be reset by going to the Settings in the upper right and clicking on General Settings on the left side.
    But to change it momentarily, go to the "Show Threads from the..." box in the lower left, select the period you want, and then click on Show Threads on the right side. This setting will disappear when you leave the thread unless you make a more permanent setting as I described.
    May 2013
    Houston
    Thank you. I found it in the settings a minute ago and adjusted it. I should have thought of that but my other few forums default to show all so I never thought about it. Thanks again.
