Results 1 to 15 of 15
Thread: Gen light on- WTF
    Jan 2013
    Leamington , Ontario
    Gen light on- WTF
    77 R75/7 Gen light on full time. Bike has relatively low miles 23000. Gel battery only 1 year old.
    How do I diagnose this? I`m not sure where to start looking and do not want to start replacing parts unnecessarily.
    I`m in Leamington, not far from Michigan and do not know any airhead mechanics in the area. I`m quite willing to trailer it several hours for good service. Any leads or pointers appreciated
    Fenwick, Ontario Canada
    1st thing to do is get this book from Motorrad Elektrik!
    2nd thing is read book.
    3rd thing, deduce step by step.
    Knights of the Roundel #333
    Pismo Beach, CA
    You are going to need to do some "wire checking"
    First thing... disconnect the battery.
    Turn your fuel tank petcocks "off" and remove the fuel tank.
    Remove the front engine cover (which is why you disconnect the battery first). Once the cover is off the bike, you can reconnect the battery... BUT disconnect the battery AGAIN before you replace the cover.
    You are looking for the obvious first - loose, broken, or corroded terminals/wire
    Here's a really good article on the subject by Kari Prager > http://www.horizonsunlimited.com/tec...ng-maintenance
    I'm not personally familiar with the /7. But I would be suspicious of the stand-offs (#8) that mount the diode board - if they are rubber isolation mounts you may have have lost "ground" to the board. A quick test would be to make a jumper cable and ground the board to the engine case. If they are rubber you should replace them with solid mounts from Motorrad Electriik.
    You can do this while waiting for the book Darryl suggested.
    Here's the wiring diagram > http://www.omnilex.com/public/bmw78/78r100wire.jpg
    EDIT - some more to read from Snobum > http://bmwmotorcycletech.info/diodebds&grdgwires.htm
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    There is a BMW Rally close to you this weekend.
    Go pick some Airhead Brains!
    Ontario, Canada
    28th ABC Rally
    Forest City Motorrad Club of Southwestern Ontario will be hosting its 28th rally at the Springwater Conservation Area in southwest Ontario from May 17?20. The rally is located on Springwater Road, approximately three kilometers south of Orwell on Highway 3, and east of St. Thomas, Ontario (N 42.750230 W 081.03331O). Admission is $50, and all motorcyclists are welcome! This includes three nights of camping, showers, continuous coffee, campfire and prizes. Friday has a 5 p.m. setup and biker stew (contribute a can). Saturday has a dice run (win a motorcycle jacket), followed by an evening barbecue and entertainment. Sunday you can tour Elgin County and go on a wine tour. Monday is cleanup and farewells. Contact Rich Stevenson (johnnydundas@gmail.com) for more details.
    BeemerBoy terham's Avatar
    Feb 2005
    Exit 31, PA TPK
    Quote Originally Posted by Darryl Cainey View Post
    +1 on this book. I recently had gen light issues with my /5 and my '83 RS and in both cases was able to track the problem with this book as a guide. I had to replace the rotor on the /5 and the diode board/grounding wires on the RS. I also recommend the solid diode board mounts from Motorad Electrik as IMO1131 says. Both my airheads now have the solid mounts. If you follow this book, I don't think you'll be replacing parts unnecessarily and should be able to find the problem. Good luck. Let us know how it goes.
    Terence
    R75/5 R100RS K100RS R1150RT
    My Smugmug
    Stage Crew beemerPhil's Avatar
    Dec 2003
    Vermont, Cape Cod, my Timberline!
    Nice bike! 75/7s are a rare bird- not many were made before they punched it out to 800cc.
    If your gen light stays on all the time, even with the key off, you're probably looking at a diode board failure.
    If the light is on all the time, only when the key is on, suspect a rotor failure. This is much more likely, esp. on an older airhead.
    If you have an ohmeter, this is an easy test. Disconnect the battery ground and remove the front engine cover. You'll see that the alternator has two contact rings, or slip rings, that are contacted by a pair of spring-loaded carbon brushes. One of the brushes is grounded directly to the stator, or alternator body. The second is connected to a black wire- this comes from the voltage regulator under the tank. Unplug the black wire. Now turn on your ohmeter, zero it, if neccessary, and check the resistance between the two slip rings. You're looking for about 3 ohms; a little more or less is fine, but a lot less is a problem.
    Rick @ motorrad has rewound and epoxy-dipped rotors for around a c-note. I used to get mine rewound at an automotive electric shop in Seattle for cheaper, but that was near 15 years ago now!
    Replacement is simple. Disconnect the remaining wires on the alternator- it doesn't matter which way you put the 3-wire plug, that gets sorted out by the rectifier, so it'll work the same either way. Carefully- I use a small screwdriver under the wires- draw the brushes out against their springs until you can push the springs off to one side and remove the tension on the brushes. Now you can remove the 3 allen screws retaining the alternator stator. The stator is often a somewhat stubborn fit against the timing cover; a few GENTILE taps will help dislodge it. Be sure that you're getting the whole thing, and not just the aluminum front cover- you want the assembly to separate at the timing cover. When it comes free, set it aside on a friendly surface; there will be wire windings exposed at the back- they're pretty sturdy, but you don't need to damage them.
    Now to remove the rotor, which is a snug taper fit on the crankshaft. This takes a 6mm allen wrench and a good yank; if the engine wants to turn, you might want to put it in gear, but I've found that if you give it a sharp pull, the inertia of the rotating parts provides enough resistance to pop the screw free. Back it all the way out into your hand.
    Now to remove the rotor...
    If you're in the business, the rotor removal tool is a good thing to have; if not, you don't need one, it's an easy work-around. I've used a cut-off piece of a 1/4" drill, about 1 1/2" long. In a pinch, roadside, one of the small studs securing the valve covers will work fine. You put one of these into the hole you just took the screw out of, as a spacer, and put the screw back in on top of it. Tighten the screw, while holding onto the rotor with your other hand, and it'll pop right off.
    Reassemble in reverse order....
    Notes:
    If there's any sign of oil leaking past the front crank seal(behind the rotor) now's the time...
    Be sure the taper surfaces on the crank and inside the rotor are clean before they meet.
    IIRC, BMW wants 17 ft/lbs on the rotor screw, but tight enough is tight enough, if you have a good wrist.
    When replacing the stator, carefully guide it into the mounting flanges on the timing cover- it's a close fit- and walk it in with the screws, a bit at a time, to keep it straight. Don't over-tighten these; the stator housing is just aluminum, and the screw bosses CAN break off...don't put the springs back into position behind the brushes until the stator is seated. Position the brushes, and let the springs down onto them gently...
    Interestingly, Moto Guzzi uses the same charging system over these years. Some bikes came with the brush carrier mounted vertically above the rotor, and they found that road vibration was bouncing the brushes off the sliprings, reducing the alternator output. A service bulletin advised us to rotate the stator to an offset position, similar to where your brushes are, to eliminate this problem.
    YMMV- Your bike could be completely different from any other BMW, or I could be thinking of my old Honda 90....
    Phil Keppelman #20331
    MOA Ambassador
    MOA Rally Stage Manager
    The shortest distance between two points.............ain't how I got here......
    Jun 2012
    Grosse Pointe Park, MI
    Good airhead mechanic in Detroit area
    If your self-diagnostic efforts come up short, BMW Motorcycles of Detroit is a first-rate shop. They work on my '77 r100rs. They are in Sterling Heights, about a 35-40 minute drive from the tunnel. http://www.bmwdetroit.com/index.htm Good luck!
    Good Airhead Mechanic
    There is a good Airhead Mechanic in Stoney Creek Ontario.
    Tomas Roeder tomas.roeder@fkn.ca
    By appointment only!
    You never have responded to any of the advice you were given?
    Jan 2013
    Yikes
    Thanks to all who responded. I had a busy week with non bike related matters and have only just started to investigate this problem.
    The battery passed a load test and seems to hold 13.25 volts at rest.
    The diode board on this /7 is directly attached to the timing cover , no rubber mounts.
    Everything inside looks as it should with nothing obviously shorted.
    I will attempt to test the regulator this weekend.
    Pismo Beach, CA
    Some light reading (get it, light reading.... )
    Read this in particular; a really quick regulator test > http://bmwmotorcycletech.info/testin...regulators.htm
    It will actually take less time to do, than read about it.
    This is the socket mentioned in the article.
    Photo: Brook Reams
    This is the terminal pattern on the bottom of the Voltage Regulator (for reference)
    Remember that BR (brown) is ground on these bikes.
    Photo: Euromotoelectrics
    And a great set of reference photo from Brook Reams' blog. http://www.flickr.com/photos/brook-r...7632545806973/
    And, an old thread where I whine a lot about my alternator > Old thread > http://forums.bmwmoa.org/showthread....ternator-check
    Happy Hunting!
    Lew Morris
    1963 Dnepr
    Jan 2013
    Now Charging
    I made up a jumper wire and tested the regulator today. It quickly jumped up over 15 volts. Shut down and plugged the regulator back in and now it is charging normally and the light goes out. It was either a bad contact on the regulator plug or an intermittent mechanical regulator. I am going to order an adjustable electronic reg. for it.
    Thanks to everyone who chipped in.
    Now on to the next problem...rich carbs
    Dec 2003
    Skip the adjustable regulator. It's more trouble than it's worth. Accurately adjusting them is a great deal more difficult than you might expect; the final voltage varies with load, temperature, rpm, and battery condition, and is maddeningly tough to nail down. I messed with these for quite a while back in the 90's when I was experimenting with a Delta system on the /7s.
    Both turned out to be of limited use, although the Delta system did make 35 amps with an almost stock system, charging starts too late- too high rpm- to be practical in normal use.
    The adjustable regulator may have some use in some racing applications, but even when very carefully set, it still seemed to wander more than the fixed regulator from the same manufacturer. (I used Transpo)
    The regulator that came on your /7 would've been a solid state Wherle; I've found these to regulate at about 13.3- 13,6 volts, absolutely NOT adequate for maintaining a 12 volt battery. I never got a good answer from BMWNA as to why they chose this regulator, when the rest of the world settled on 14.2-14.5 volts, but the first thing I look for when an airhead comes in with weak starting/battery issues is an oem reguilator. It was junk right out of the box, the Transpo unit will solve 90% of these cases.
    If you coat the terminals with vaseline upon installation, you'll probably never have to touch it again. I've installed quite a few of these, and seen only one failure over many years-
    MOA Ambassador
    Jan 2013
    fixed rewgulator
    Thanks Phil
    I had a last minute change of heart and ordered one of the non adjustable electronic ones.
    will pick it up this weekend.
    Peter
    Pismo Beach, CA
    Voltage regulator non-BMW substitutes:
    NAPA Echlin ECH-VR503
    Borg-Warner R-588
    Transpo IB301
    Slight differences between OEM BMW being it's form is somewhat smaller and the output terminals are on a short "pig-tail" vs. fixed on the bottom of the regulator. A bit of a hassle figuring out what to do with the extra loop of cable but worth $40 savings over OEM, IMHO.
    Lew Morris
    1963 Dnepr
    Dec 2003
    The Transpo IB301 is what I've been using for years. It doesn't have the pigtail, just plain male terminals on the bottom of the epoxy-sealed case.
    The adjustable unit is the IB301A....and they're both way cheaper than oem.
    MOA Ambassador
