Results 1 to 5 of 5
Thread: My heated grips are oval after 74K miles in 3 years!
    "Natural Born Chiller"
    Isle of Palms SC
    Maybe I just need a Chill Pill? Anyone out there changed these?
    you didn't add your year model...so assuming it's an 1100/1150
    you can change just the rubbers, you need two throttle side grips from a non heated grip setup . The GS parts fiche has the number 32 72 1 458 396 RIGHT GROOVED HANDLE. About $10 bucks apiece
    Slowly lift the flange end with needlenose pliers to seperate rubber from foil of heated grips and cut with razor blade/exacto knife down the length as you slowly pull apart with pliers . Spray some 409 on the new rubbers and slide in place...the 409 will dry in a day or so and grips will be tight
    Steve Henson
    blast of air to help the separation has been suggested, with less likelihood of cutting anything you don't want cut. I will be doing mine in another week or 2, 96K miles.
    SE Wisconsin
    Mine were pretty worn out at 75K mi. Been wrapping them with 'grip tape' from the sporting goods store ever since. $5 every two years or so...
    Isle of Palms SC
    Thanks!
    Good Ideas!
