Results 1 to 10 of 10
Thread: Gearing on R80RT
    Brian
    Jan 2011
    Laguna Niguel, CA
    Gearing on R80RT
    Has anyone had any experience changing the final drive on an R80RT? I have an '86 that I resurrected from 20 years in some guy's garage. I'm a little surprised how fast it spins at speeds I need to do (80 MPH is 5,000 RPM). In So. Cal. you do this or get run over. Thinking of trying to fit an R100 final drive to bring the revs down. I'm OK with the power so that's not an issue.
    Fenwick, Ontario Canada
    Changing the rear drive is not hard at all 4 nuts + 1 on the shock and a new gasket.
    You do realize that your speedometer will be off unless you change that as well!
    What ratio do you have now? Small numbers stamped on the rear drive housing like 33/11 = 3:00 ratio.
    Knights of the Roundel #333
    Brian
    Jan 2011
    Laguna Niguel, CA
    Quote Originally Posted by Darryl Cainey View Post
    Thanks for the speedometer info - I didn't know that. The current ratio is the stock 37/11.
    Pismo Beach, CA
    The old story goes that Dusenberg salesmen used to boast that their cars would top 120mph, and they had a box of substitute gears to ensure that they would.
    BTW, what's wrong with 5,000 rpm?
    Lew Morris
    1973 R75/5 - original owner
    Registered User jad01's Avatar
    Houston, TX or Portland, OR
    I replaced the original 37/11 final drive on my '78 R80/7 with a used 34/11 some years ago. It is a relatively modest change, but I really like it compared to the lower gearing of the original. It was just enough to bring the revs down to nearer 4250 rpm during highway travel (~ 65-70mph), without making the bike feel sluggish or geared too tall in town. There used to be a nice technical article on the IBMWR site comparing different FD ratios and their appropriateness for different engines, but I don't see it there any longer. I'm not sure how the outright power of your model compares to mine (or the effect of the full fairing), but I suspect it would be reasonably similar. I did not bother replacing the speedo. I just benchmarked it compared to my GPS at different speeds (for reference- I rarely ride with the GPS in place) and subsequently calculate the approximate odometer error when figuring maintenance intervals and fuel mileage.
    Jim
    '78 R80/7 and '84 R100RS (Blues Brothers), '86 K75C (Icy Hot)
    '90 and '93 Mazda Miatas (Jelly Bean and Red Hot), '02 325ci (Blue Streak)
    '96 Giant Upland (big Kendas & freshly greased bearings!)
    Administrator 20774's Avatar
    Anton has a gearing comparison chart on his website:
    http://www.largiader.com/articles/gearing/
    It used to work...click on your bike and gearing then see what other final drives will do for speeds. Doesn't seem to work for me right now...
    Albuquerque, NM
    BMW knows what it's doing and fits the best rear drive ratio.
    So, if you change to an R100 ratio, you should change your cylinders, heads, and carbs to R100 items as well.
    Or, you could just get an R100RT. You might even get better fuel mileage if you do.
    Kent Christensen
    21482
    Beemerphan Radar41's Avatar
    May 2003
    Longmont, CO
    Cool Rear Drive Change
    Quote Originally Posted by bwing View Post
    I just changed the rear drive on my R75/6, from the 37/11, same as you have, to a 32/10.
    This is a common swap and a well tuned, and in good order, 750 cc or 800 cc engine won't know the difference! The 32/10 drops the engine rpm by 213 rpm @ 70 mph. This will of course throw the speedo off a bit but who cares? GPS's are cheap and easy to mount.
    Just one thought.
    Don "Radar" Wreyford
    00 K1200LT, 98 R1100GS AE, 84 R100RS, 76 R75/6
    MOA # 91738, RA #27032 , ABC #7915 - "Insanity is doing the same thing over and over again, but expecting different results" - Albert Einstein
    Brian
    Jan 2011
    Laguna Niguel, CA
    Quote Originally Posted by Radar41 View Post
    Just one thought.
    Thanks for all the input. It's more of a 'I'd like to do it' rather than a 'I have to do it.' I'm just more used to slower spinning R100's. This R80RT just feels tapped out (redline is 7,500 RPM). Also, the gas mileage drops a lot when it's spinning like this.
    Pismo Beach, CA
    Well, it's literally a four-nut, half-hour swap, and you can always unload a final drive without loosing your shirt on eBay if it doesn't feel right to you.
    Lew Morris
