Results 1 to 5 of 5
Thread: 1972 R75/5 Sidestand - Favor?
    Could someone with an R75/5 do me a big favor? With the bike on the center stand, pull out the side stand and measure the distance from the bottom of the "foot" to the ground?
    I believe my side stand must be bent. The bike leans way, way over. Far too far for my taste - and looks like it's about to fall over.
    I've looked at pictures of stands online, but it's difficult to gauge the geometry. A quick measurement would confirm my suspicions - Thanks.
    Pismo Beach, CA
    Mine used to do that too. The sidestand was bent; way bent (and what's more I remember how I bent it). I replaced it with a Browns.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Jul 2010
    Eugene Or.
    Let me preface this reply by saying I don't believe my side stand to be a stock part but the angle the bike sits at on the stand is just right. When center-standed and I flip out the side stand it's tip is 4" from the floor.
    (Like many of these old bike threads one answer raises another question... even on my center stand both of my tires are in contact with the ground, they can be spun but requires some effort, my center stand appears to be the factory part so I've always wondered if this is normal? I thought the purpose was to get the tire, front or rear, off the ground so it could be removed?)
    1970 R75/5 Old Faithful
    2013 F800GS New Flame
    Quote Originally Posted by bustedknuckles View Post
    If the centerstand is indeed stock, and the tires are touching the ground, then either the bushings or the stop point for the stand are very worn. Here's a link to a picture of a stock /5 on its centerstand...the front wheel should be well off the ground:
    http://www.bmbikes.co.uk/photos/phot...hite%20002.jpg
    The most common ride-off stand is the Reynolds ride-off, shown here:
    http://w6rec.com/duane/bmw/reynolds/reynolds9.jpg
    Wisconsin and Florida
    1972 R75/5 with mostly unused side and centerstand in original condition
    Installed brown sidestand years ago when bought low mileage bike - never used orig stand since
    Seldom use centerstand due to bad back - need to be at shop to roll up on 2x boards to deploy
    On centerstand with front wheel on ground and rear off dist up to sidestand foot is 3 1/2 inches
    On centerstand with rear wheel on ground and front off dist up to sidestand foot is 4 inches
    Tires true old style 3.25 x 19 front 4.00 x 18 rear
