Results 1 to 8 of 8
Thread: 1976 R75/6 Instrument Cluster
    Feb 2013
    Two questions to start: I would like to replace the (missing) hood over the tachometer and it looks like someone may have glued the lens bezel on with something like rubber cement or contact cement. It is still "gummy". Then there was a layer of black tape wrapped around the bezel and the case. I have been having trouble uploading pictures but I am going to try. Can anyone give me detail on how this assembly is supposed to be? I don't want to do any damage getting it apart in order to clean it and put it together right. Second thing is that the tachometer cable was broken when I took possession of the bike. When I took the instrument cluster off, the tachometer would not turn. I imagine that is why the cable broke (the end going into the engine was broken off in its receiver). I turned it backward with my fingers and it freed right up and now it turns with some "lumpiness" but basically pretty smooth. Is there any service that I can do to make sure whatever hung up the cable in the first place isn't still "lurking"? Any advice or direction to detailed instructions would be appreciated. I have to get my "tech" to help me with pictures (unless I can get the 8 year old kid who lives next door after school lets out!). I keep getting the same error messages when I try to post photos.
    Thanks,
    Chip
    Quote Originally Posted by cseltz View Post
    What is the error message? If the original picture is too big, it won't upload. Find a way to knock the size down to say 150-200Kb and it should upload fine.
    Sep 2003
    Virginia Beach
    Hoods are available, new - perhaps not from BMW, but I have seen them. The part underneath the hoods (holding the glass) was originally glued on. After a while, the glue gets brittle and lets go. My glue wasn't gummy. I just used electrical tape to secure and that has been waterproof.
    Virginia Beach
    current:14 R1200RT 75 R60/6
    Feb 2013
    I know the problem is at my end. Sometimes the pictures come through and sometimes I get an "upload failed" message. The next time my tech is here, I'll get him to go over it with me and figure out what I am doing wrong. That will be Sunday at the latest (he is my son!). Thanks.
    Feb 2013
    Quote Originally Posted by Weasel View Post
    Thanks for that input. I have the new hood and it looks like it is meant to fit into a "groove" at the base. So you wrap with electrical tape and then fit the hood over the outside?
    Feb 2013
    Now that I am into this, I could use some direction regarding disassembly / reassembly of the pod. There is a broken gear linking the tachometer to the cable landing but I am stuck getting to it. Is anyone aware of a site where I can find detailed diagrams / procedures?
    Thanks,
    Chip
    Chip -
    Go to the link in my signature line and look at the section the Speedometer. There are several tutorials on opening up the speedo pod.
    Sep 2003
    Virginia Beach
    The hoods do fit into a groove...after I re-glued the glass/plastic portion, I then wrapped in electrical tape around the hoods just for good measure. This was just a precaution because I ride in the rain quite a bit, and I didn't want any moisture coming in, just in case my glue job wasn't up to snuff. Electrical tape was just a precaution in case my glue job failed. Originally, the whole assembly had popped off after having run over a huge pot hole.
    Virginia Beach
