Results 1 to 11 of 11
Thread: R1100RT Auxiliary Fuse Block Location
    143439 bobr9's Avatar
    Jun 2012
    Clarkesville, GA
    R1100RT
    Looking for feedback from folks who have installed an auxiliary fuse block (fuzeblock, pc-8, centech, etc.) on a R1100RT to see where they have located the device on the bike. Thanks in advance.....
    Quote Originally Posted by bobr9 View Post
    R1100RT
    I have a Centech installed on my '99 R1100RT and it sits on top of my air cleaner box.
    JB
    RK Ryder
    London, Ontario
    Quote Originally Posted by jbeaver124867 View Post
    JB
    Does that work with the seat in the low position?
    Paul
    Knights of the Roundel #333
    Jun 2012
    Clarkesville, GA
    That would be my question as well, and did you have to do anything with the temperature sensor that is mounted on top of the air cleaner lid? This would be an ideal location otherwise.
    Manitowoc, Wisconsin
    Contact Hotspice (Tony) of Cyclenutz. He has a plate that uses the screws for the diagnostic port holder and angles toward the tank. I used one on 1150GS and 1150 RT-P and everything fits quite nicely.
    F.O.G.Rider, Rounder #6,
    Ambassador
    BMWRA Wisconsin Region Rep
    MOA Biergarten co-chair
    DBLUPPR snookers's Avatar
    Jul 2010
    Southwest of Beamsville
    I would have to say Absolutley !! as I have my seat in the low position with the CENTECH mounted on top of the air filter box.
    NOTE: should you mount the fuse box here, leave enough wiring from the battery to accomodate the lid when removed from the air box.
    Here's a pic of mine......it also shows the external fuel filter mounting as well
    2000 R1100RT
    Niagara BMW Riders #298
    BMWMCO #45
    Jun 2012
    Clarkesville, GA
    Quote Originally Posted by snookers View Post
    Neat!! Thanks for the pic, very helpful. Where did you tap in for your 12 V relay signal? Bob
    Jul 2010
    Bob.....the Centech Fuse panel on my bike is "HOT" all the time.......with that said.....all accesories wired to the panel except one, which is wired to my tank bag, are on relays which allow power only with the key in the on position. I found a switched hot wire in a bundle tie wrapped to the support strut for the front upper fairing. I believe it was for the radio which I don't have.
    2000 R1100RT
    BMWMCO #45
    Bmuused BMUUsed's Avatar
    Apr 2012
    Lemont, Illinois
    Left side, by the lift handle. Shown with cover removed. Runs fog lights, aux. driving lights, heated grips, marine amplifier for mp3 (no radio), pigtail for heated vest, stealth cloaking device and a few other things that I don't remember.
    At the tender age of five, a bear told me that only I could prevent forest fires. Why I was chosen, I'll never know.
    May 2006
    Northern New Jersey
    I don't think most accessory fuse blocks are waterproof, so keep that in mind too when choosing a location.
    Jul 2010
    Cool
    A valid point....thats why mounting ontop of the air box is such a good choice IMHO.....the seat protects the unit quite nicely. I have ridden through torrents of rain with no ill effects. A peice of plastic or the top of a yogurt container over the fuse panel can be added for peice of mind.
    2000 R1100RT
    BMWMCO #45
