Results 1 to 2 of 2
Thread: R75/5 Headlight Lens is crooked (rotated slightly) How to fix?
    Apr 2012
    Los Angeles, CA
    Hi all!
    The headlight lens on my R75/5 is crooked. Its actually not situated exactly level. (It's been turned slightly around its axis).
    How does the lens remove from its chrome ring?
    Pismo Beach, CA
    The whole operation is held together by the spring clips (#2) The lens is fitted to the reflector with a gasket - BE CAREFUL - there is no adhesive and sometimes the lens can separate from the reflector and end up on the floor.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
