Results 1 to 11 of 11
Thread: R90/6 '76 removing steering damper
    Registered User plehman's Avatar
    Nov 2006
    Arlington, MA
    The steering damper never worked on my /6. Well, not in the 6 years I've had it. Thinking of removing it after seeing a nice cafe version.
    Any issues there? It looks like it should come out pretty easily.
    My bike in front. The bike without in the back. Just another day at Duncan's Beemers in Maynard Mass.
    My manual referred to "removal of wire retainers". There were none. A bit of leverage with a screwdriver popped it off. Mine is an R75/6 but the same year.
    Registered User dmftoy1's Avatar
    Mar 2012
    Lexington, IL
    Fwiw mine had wire retainers but removing them didn't "release" it, still had to "pop" it off - ymmv
    Nov 2006
    Arlington, MA
    Center bolt
    What about the long bolt in the center? Did that just pull out?
    Fenwick, Ontario Canada
    Yes, it comes out the bottom after you remove the 2 small Allen screws that hold the steering dampener adusting mechanism. The rectangular box has a slide adjuster with a gear drive.
    Knights of the Roundel #333
    Registered User stanley83's Avatar
    Oct 2009
    Somerville, MA
    Very easy to do
    As mine was doing nothing, I removed mine. Took off bolts and it just came off.
    ps. Where in Arlington are you? I'm just over the line in Somerville and work at Quad Cycles on Mass. Ave. in Arlington.
    Justin in Somerville, MA
    _________________________
    76 R75/6, 78 P200E, 63 VBB
    Lots of bicycles
    Nov 2006
    Arlington, MA
    Ps:
    Cool, I love Quad cycles. I live just up Robbins
    Pismo Beach, CA
    A cafe BAGGER!!! I like the way the angle on the back of the bags kind of reflects the angle on the back of the seat.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Nov 2006
    Arlington, MA
    Yes, dropped right out. Was surprised that the 37 yr old damper actually had a little life in it. I'll ride tomorrow to see if you really don't need it.
    Anyone have an opinion damper vs no damper?
    Administrator 20774's Avatar
    Quote Originally Posted by plehman View Post
    A well set up bike, proper condition tires, etc., shouldn't need a damper. If you're running over cobblestones, rutted road, or pulling a sidecar, you could use a damper.
    Sep 2003
    Virginia Beach
    Damper set to "2" is good on gravel roads or on icy roads, and also keeps front end from wandering on rain grooves.
    Virginia Beach
    current:14 R1200RT 75 R60/6
    past: 11 R1200RT 10 R1200RT 03 R1200CLC
