Results 1 to 9 of 9
Thread: Wethead service checklists
Hybrid View
    An advrider member has posted the pdf's for the 600, 6K, and 12k service checklist for the 2013 R1200GS WC that he got from his dealer.
    http://www.advrider.com/forums/showt...php?p=21319940
    AZ
    Why would they replace (and not just check), the spark plugs at 12k miles? I have over 30k on my current plugs and they look and perform as new.
    MOA #107139
    RA #28511
    YB #2005
    I don't know the answer.
    However, on my hexhead the plugs were typically worn beyond the max 1.0 mm gap at 24K miles -- the BMW recommended service life. Sure, I could probably have re-gapped the plugs and put them back in the bike, but why? I put in new plugs then mostly forgot about them for the next 24K miles.
    Perhaps I feel that way because 24K miles is about 2 years worth of my riding that bike. If I were putting 30K/year on the bike I might feel different.
    The good news is that there's only 2 spark plugs to replace, not 4!
    Warmest regards,
    Doc Reid Hester
    Wondering about your drinking? Consider our FREE Drinker's Checkup
    Get saddlesore when riding? Check these shorts out
    Keep in mind these are live documents and are subject to change. Given this is a first year motor there very well may be changes as time goes on and they discover issues they didn't anticipate. Ideal scenario is to ask a dealer to print up the appropriate doc for you when you're ready to perform the service.
    Thank you for the heads up on the current documentation.
    Wilmington, NC
    The 2X shorther interval has to be based on either 2X the spark frequency or higher energy causing faster gap erosion.
    All modern BMWs will start and run with gaps opened way beyond the wear spec- but at the risk of costing a coil. Not really worth it.
    I own a hexhead and agree with marchyman- my mearuements and photos put the plugs slightly over the gap wear limit of 1.0 mm at 24K miles. I use an alternate plug- same as the factoryy one except it has a platinum electrode and is a lot cheaper because its commonly used in BMW 6 cyl cage motors so is at every parts place..
    Kool Aid Dispenser! jimvonbaden's Avatar
    Mar 2004
    Alexandria, VA
    Quote Originally Posted by billy walker View Post
    I'll keep the documents up to date as I receive changes.
    For now, direct links:
    LINK TO WETHEAD SERVICE SCHEDULE!
    Link to Tool Lists Download in Word Format!
    Link to Valve Chart!
    Link to Torque Values!
    Jim
    Registered User dancogan's Avatar
    Aug 2004
    SE Michigan
    Quote Originally Posted by jimvonbaden View Post
    Jim
    Thanks, Jim!
    Dan
    The spark plug replacement interval was halved upon transition from hexhead to camhead. The plugs on the later models are much smaller. There's less material to erode in the first place.
