Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Thread: Anyone using BMW aux led brake lights?
    May 2011
    South Kentucky
    I'm considering adding additional brake lights on a 12GS. The BMW lights look interesting
    Anthony S.
    2012 R1200GS
    Debbie's Servant Lee's Avatar
    SW Iowa
    Not on a GS, but K1300S.
    Dealer installed them on our bikes at purchase and they work great.
    Lee
    2016 R1200RS
    MOA # 30878
    Dec 2005
    East Texas
    I had one on my R12C Montauk. Cars seemed to stay further back. Intend on putting one on my new RT.
    Mar 2011
    socal
    Didn't use the BMW aux light, went with skene design P3 lights
    So far I've done about a dozen installs for friends, who couldn't or wouldn't ride without them
    Great light
    I like them and have one on 2/3 of my bikes but some prior information could be helpful.
    The BMW light is on whenever your taillight is on and when you activate brakes the light blinks brighter rapidly maybe only twice and then remains lit brighter, just like your brake light. It's pretty subtle, and almost a flicker, but I imagine it's effective.
    As with everything else, factory styling is better than aftermarket styling and of course these are made to fit your bike so it's plug and play and there's no modification to existing wiring.
    May 2011
    South Kentucky
    It looks like it's either the BMW or the Skene. Both have advantages.
    I wish I could see them on a bike
    Anthony S.
    2012 R1200GS
    Motorsickle Rider brisco's Avatar
    Oct 2010
    De Soto, KS
    Skene P3 an current RT and I'm put them on my last three bikes as well.
    Ordering a set today for my son's new bike.
    They keep drivers way back due to the flicker when close.
    I like the adjustability of the brake flashes, I run with four quick then on solid.
    Kansas. Eleven curves in three hundred eighteen miles...
    '09 R1200RT
    N0PGH
    Iron Butt Assoc. #47865
    May 2011
    South Kentucky
    Question and answer--- BMW LED AUX brake light
    Will this model brake light Part Number ? 63000445578 come complete with wiring harness to fit 2012 BMW R1200GS
    Good morning,
    Unfortunately the current led light will not work on the 2012 models. BMW made a software change on the bike that wasn?t communicating with the led light. They are making a new one that will work. Hopefully it will be available this year.
    Francis Jordan
    MAX BMW Motorcycles
    Anthony S.
    2012 R1200GS
    This isn't my bike, but from Twisted Throttle add.
    Everyone riding behind me says it's great.
    Running light, stop light and turn signal.
    Old But Not Dead
    Semper Fi
    Jack Herbst
    Jan 2008
    Oro Valley, AZ
    Quote Originally Posted by t6pilot View Post
    Great light
    Couldn't agree more. I like the constant flicker. Great Product!
    Quote Originally Posted by jaherbst View Post
    +1 on the skene's excellent product, easy to install
    John
    May 2011
    South Kentucky
    It seems Skene has a lot of support here. I'll give their lights a try
    Thanks for all the helpful information
    Also as I posted earlier the BMW lights aren't compatible with the 2012 software
    Anthony S.
    2012 R1200GS
    Kbiker BCKRider's Avatar
    Jan 2009
    B.C. Canada
    Sloride, you might also consider the Skene front LED's. I have both on my bike and believe they are a big plus in garnering the attention of motorists coming toward you as well as ones following you.
    All kinds of theories on what works best - and, of course, NOTHING works infallibly. The other day I saw what resembled the light of a train approaching me! Only when it got really close did I realize it was a motorcycle with three headlights in triangular formation, apparently all on "bright." What I saw in broad daylight was ONE huge light with no clue this was a motorcycle. Probably not the effect the rider wanted.
    Doug
    1992 K100RS
    Nibley, UT USA
    i have the Skeen P3 on one bike, and the BMW aux light on another. The BMW light has always functioned flawlessly, the Skeen had one block of 4 LEDs go dead and has been problematic in that it periodically goes into constant flashing mode even without the brakes being applied. Skeen was of no help when I called them and I couldn't find paperwork on when the lights were purchased, which I found to be quite a bit different experience that what I had with HyperLites, who replaced without question a 2-yr-old unit that went dead.
    So I'm done with Skeen and will likely be pulling it off and installing the BMW aux light in it's place.
    YMMV, as always.
    Best,
    GTRider
    UPDATE: After posting the above I was contacted directly by Jerry Skene. It turns out that we had a cross-up in our communication where we were both waiting to hear from the other, so nothing was happening. Jerry explained that they were temporarily out of the controllers but would be sending me a new set of lights and a new controller as soon as they were restocked. I received the lights this last weekend (5/31) and will be mounting the new replacements this weekend. So, I take back everything I said above and apologize for the unwarranted grousing-- you can't call it anything but top-notch service when a vendor tracks down a customer and stands solidly behind their product! BTW, the new lights are reported to be a bit brighter than the old, and the controller beefed up as well so I will report back on that after this weekend's farkeling. So, a big Thank You to Skene Design!
    Now I'm thinking I need a set for my airhead....
    Best,
    GTRider
    DGerber
    1983 R80ST -- 1988 K100RS (r.i.p.) -- 1995 R1100RSL (gone, never forgotten) -- 2004 K1200GT w/Hannigan S/C -- 2010 K1300GT
    That road looks good! Norwood's Avatar
    Aug 2005
    From NW AL to WNC
    +1 for skene design P3 lights as well...
    Great customer support...programmable...can re-program by using brake lever... several lighting options.
    Turn signal and four way as well... also Volt meter signal as well.
    MOA Ambassador, Member of AL, GA and Chattanooga Clubs, MTF Gold member and BOD.
    2011 R1200 GSA (My Radio Flyer) 75 R90/6 with Velorex sidecar
    My annual charity event: http://www.echbenefit.smugmug.com/
    " Oh Lord I pray, Let me live long enough to do everything they say I've done"
