Results 1 to 4 of 4
Thread: 75/6 wiring harness under alt cover
    Sep 2006
    Been replacing leaky seals & gaskets and took several shots of wiring when removing points and diode board to remove timing cover ...BUT they didn't capture everything dangit! I'm close but not 100%
    Anyone have a clear shot of routing? Had it only been one day I might have remembered!
    Steve Henson
    Administrator 20774's Avatar
    Steve -
    I hunted around and found the following:
    http://forums.bmwmoa.org/showthread....l=1#post619495
    http://forums.bmwmoa.org/showthread....l=1#post644456
    There's a picture or two on this page, but it might not be near enough to your situation:
    http://www.rapiddog.net/BLOG/BUILD.htm?t=180701
    I have a good picture or two but every attempt to upload to the site has failed. If you send your e-mail address, I will forward it to you.
    Chip Seltzer
    Sep 2006
    I sent you a PM Chip...
    Thanks Kurt...the Katrina bike damage is hard to look at still in the second link, post #35
    Steve Henson
