Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: Mini Air Compressor
  1. #16
    Registered User liv2ride's Avatar
    May 2012
    Honolulu, HI
    Quote Originally Posted by Stig View Post
    I have this one from Adventure Designs. It's expensive for a mini pump, but I've had it for like 5 years now and use it to inflate my motorcycle and Toyota truck tires without a problem. Gets warm after the 4th truck tire but never overheated. Comes with the BMW plug and an adapter for regular cigarette lighters.
    I suspect you don't use the BMW plug in the factory receptacle that is connected to the CANBUS, or do you? From what I have seen all of these devices exceed the 5A trigger, disabling the port and generating a fault code.
    I have been looking for a compatible inflator but I will likely settle for one with clips for the battery.
    2012 R1200RT - Fluid Grey Metallic
  2. #17
    Canada and the Alps
    Quote Originally Posted by liv2ride View Post
    What, you need a BMW plug or battery to inflate tires?
  3. #18
    MOA #188066 tf78933's Avatar
    Sep 2012
    Jacksonville
    I just rewired the end of my pump with the same fitting used for the trickle charger. I just plug it in and it works off the battery. no need for clips
    09 R1200RT, no longer own 99R1100RT, 98 Honda Shadow 1100, Penton 125cc six days, Hodaka 125cc Wombat
  4. #19
    Tame Racing Driver Stig's Avatar
    Dec 2009
    Hudson Valley, NY
    I run the pump off the factory 12V plug on my RT and have never had a CANBUS "blown fuse" issue
    Craig
    New York's Hudson Valley Region
    2009 R1200RT
    MOA #146131 IBA #55715
  5. #20
    I've have had this one from Harbor Freight going on 5 years now without a problem. Works every time and and it fits in the radio box storage area on my RT. And did I mention it's only $10 bucks!
    http://www.harborfreight.com/12-volt...ssor-4077.html
    -Ride Safe & Avoid Anyone On The Phone-
    **2000 R1100RT (Bullfrog), 1976 R90/6 (Tadpole)**
    beemerFROG a.k.a. Douglas E. Rost
    MotoFrog.net -- Black Frog Marketing
  6. #21
    May 2012
    Honolulu, HI
    When I first bought my bike I used the inflator I keep in my car. It would work for several seconds then the CANBUS would interfere and disable both factory outlets, throwing a code in the computer. After cycling the key the computer would reset but the inflator would again, trip the outlets. Subsequent research showed the 5A limitation for the factory outlet, I have been looking for a compatible inflator since.
    Being that your bike is a 2007, do you know the maximum amp draw allowed for your outlets? Do you know the amp draw of the inflator you are using?
    Thanks in advance.
    Scot
  7. #22
    May 2012
    Honolulu, HI
    Quote Originally Posted by derost View Post
    Interesting, certainly looks tempting from the size/cost standpoint. Do you have the specs on amp draw for that unit?
  8. #23
    5A is the GS limit. The RT is reported to have a 10A limit. I don't have a copy of the RT manual on hand to verify.
    FWIW my cyclepump draws around 5A -- it will run from the accessory socket unloaded. When actually attached to a tire it starts pulling more than 5A. Glad I did my initial test by actually trying to put air in a tire.
  9. #24
    May 2012
    Honolulu, HI
    Now I feel a little silly, you are right about the RT and 10A limit. I just checked the owner?s manual and sure enough, 10A for "all" sockets. I am just not sure if that is in anyway divided between the two for 5A each.
    Now all I need to figure out is how the draw changes from unloaded to loaded i.e. pump running when not filling vs. running while filling.
    Any ideas on how this can be determined?
  10. #25
    I believe the sockets are in parallel, giving you a total of 10 amps in any configuration you like. If you are pulling 10A from one you've got nothing left over for the others.
    A good multimeter will let you measure current up to about 10 amps. The issue is that you have to break the circuit to put the ammeter in series with the load. In this case it's probably not worth the effort. Turn on bike. Plug in pump. Pump up tire. Did the bike turn off the outlet? If not you are under 10 A. Is the exact amount really important? I don't think it's too much of a hardship to turn off other electrical farkles during the 3-5 minutes it takes to pump up a tire.
  11. #26
    Quote Originally Posted by beemergirl View Post
    We have a couple of these: http://www.aircompressorsdirect.com/...sor/p7627.html
    that I picked up on sale for 10 bucks at an auto parts store.
    I use them all the time. Much more convenient for putting a couple lbs of air in your tires than a big compressor. Just hook it to a powerlet adapter, plug it in and you're set. Often gas station air compressors don't work or don't fit our wheels....so this allows us to inflate anywhere. I've used it on the side of an interstate as well, to get to the next ramp where the tire was flat again.
    I'd say the regular price is OK, but if you can, wait for a sale.
    Nancy
    Great idea Nancy. Thanks for sharing.
    Dan Schmidt
    http://www.vestedbb.com
    2005 BMW R1200RT
