Results 1 to 2 of 2
Thread: Heated grip connector question
    I replaced a failed aftermarket heated grip switch with the OEM switch. The OEM switch came with a standard molded plastic female connector which I'm trying to connect to the old wiring which has no connector. The female connector internal pins are smaller than anything I can find at Radio Shack, does anyone have a source for molded plastic male connector or very small male pins I can solder onto the old wires for plugging into the female connector?Thanks for any advice.
    Unfortunate that this was moved from Airheads section which I'd assume is the bike. Anyway, look first through the BMW parts system.
