Results 1 to 9 of 9
Thread: GPS connectors on hexheads and cam heads
    Cowboyatheart
    Feb 2009
    Pender Harbour, B.C.
    Hi Everyone,
    I put this question in the "08 GPS connector questions" thread, but realize that that thread may be too specific and NOT attract attention to readers to elicit responses.
    BTW I do have a 2008 RT, however, this covers more than RTs
    So I pose it here....
    A friend of mine said his garmin zumo 660LM harness (that came with his GPS) had an end that plugged directly into the BMW GPS plug on his RT.
    Plug and play as it were.
    Why does everyone say another part is needed? (see other threads).
    Moringa, your body & brain will thank you! PM for discounts Smart Mix at TasteMoringa.com
    XM3 Energy, real energy for the body & brain, no sugar high, XM3.Energy
    Was his GPS purchased as part of a package for BMWs?
    Did his RT come with (or did he purchase) a bike specific GPS mount? I believe some mounting kits come with all needed adapters.
    My GS did not come with any kind of GPS preparation and my GPS (not a 660LM) came with a car cigarette adapter. I needed to do some surgery to the cable to get power from the bike to the GPS.
    Cowboyatheart
    Feb 2009
    GPS connector
    No regular 2010 RT, GPS from garmin with a standard order, nothing special.
    Registered User websterize's Avatar
    May 2009
    Frederick, Md.
    Quote Originally Posted by cowboyatheart View Post
    Four years ago Garmin shipped the 660 cradle with bare wires, which required the BMW repair connector (yellow wires below).
    I didn't like using the 660's touchscreen with gloves -- too much of a distraction from the road -- so I returned it for the newly released Navigator IV. Its mount plug (white below) was plug-and-play with the switched accessory connector on the bike. And the Navi IV cradle has chunky, backlit haptic buttons that work great with gloves.
    Inside newer 660 boxes, apparently, Garmin's motorcycle mount now includes more than just bare wires.
    Bill Webster
    2013 K 1600 GT
    2009 R 1200 R alumnus
    Spring Lake NJ, USA
    Hi Everyone,
    I would have to question exactly what your friend ordered. It sounds as if it's a special setup.. no 660LM that I know of comes with the BMW plug - which would be useless to the majority of other brand bike owners.
    Can you get us any details on it? Was it new? From a special vendor?
    Registered User sickticket's Avatar
    Oct 2012
    Dublin, Pa
    Quote Originally Posted by websterize View Post
    The white repair plug with yellow wires is exactly what I am dealing with. I will be using that with my Montana GPS on my 2013 R1200RT. My problem is I am not sure where the white plug goes. There is a black plastic plug to the right of the steering head below the right light frame. I can't get the protection plug out of the black plug. Any suggestions? Also, to remove the mirrors is the hex set screw take a 3.5mm Allen wrench?
    May 2009
    Frederick, Md.
    Quote Originally Posted by scalese01@verizon.net View Post
    My problem is I am not sure where the white plug goes. There is a black plastic plug to the right of the steering head below the right light frame. I can't get the protection plug out of the black plug. Any suggestions??
    There's a black cap on the bike's accessory connector. Pull it off and plug in the white repair plug (with yellow wires) into it. Here's the connector with the cap removed.
    Bill Webster
    2013 K 1600 GT
    Sep 2008
    Wilmington, NC
    For many gps,that were common when the 08 was built, like the 550, you can clip the middle wire out the repair plug- its not needed to go to the gps. The two outside wires are you 12V and ground- just look at the bike side of the plug and as alaways brown is ground, the other outside wire is your power...
    Oct 2012
    Dublin, Pa
    Thanks for the replys. I will check it out tomorrow when home. Installed the bracket and support today. Wire tomorrow.
