Results 1 to 8 of 8
Thread: checked valve clearance on my 2010 r12 @ 6k mi
    mattituck new york
    the clearance was fine. has this been the experience of most owners here? i'm thinking maybe its because i'm an old fart (67) and drive like one.
    Polarbear Polarbear's Avatar
    Clovis,CA
    Common:)
    You have a bucket shim system, mine the '07 with tappets. BUT, not any difference in what you found. I am at 95000m now, with only the slightest valve adjusts or none during that period. My last 2 checks were NO adjusts. They rarely get out of adjusts. Same with all my past bikes for a decade or more now. These newer engines are built better perhaps than our old days! That said, I have a '78 R100/7 since new with ORIGINAL valves at 388000m now, wow. Enough said. Randy
    Jul 2007
    THE BIG SKY
    I've read several posts by Hexhead riders saying they have not had to adjust valves on bikes with 40-50k miles. My R has 24k and the valves have stayed in spec. I just did a service on a friends RT with 42k and it had three intake valves that were a little tight. So, not uncommon for them to be in spec at 6k.
    Throttle body sync is another area that seldom needs adjustment.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Yakima, WA
    At my recent 600 mile service (performed all items myself) I adjusted two valves, one intake and one exhaust, that were both right at the edge of the range. I also did a throttle body sync using both a GS-911 to lock the steppers and a TwinMax, it is noticeably smoother now.
    I could have left the two valves but I feel better now knowing they are in the center of the range. Anyone familiar with that feeling? ;-)
    Randy
    CURRENT: R1200GSW, R75/7
    PAST BMWs: 2013 R1200RT, 2002 R1150RT, 1982 R100RS, 1993 K1100RS, 1993 K1100LT, 1989 R100RT, 1978 R80/7
    Dave Nicholls 105258's Avatar
    Mar 2004
    Teulon Manitoba Canada
    2010 RT Valve Adjustment
    I have 65,000 k on my bike and so far the valves ar still in spec. I check them every 20,000 kms just to make sure.
    Dave Nicholls
    Teulon Manitoba - Canada
    2010 1200RT
    Jul 2007
    THE BIG SKY
    Ed, Is yours a Hex or Camhead? My comments assumed Hex.
    Kevin Huddy
    mattituck new york
    So far Camhead in spec, 6,000 miles. I don't expect it to change.
    David
