Results 1 to 3 of 3
Thread: RT-P Cooling Fan Questions
    Fire Don't Burn Motor unit 7's Avatar
    Nov 2006
    Leamington, Ontario, Canada
    Unhappy RT-P Cooling Fan Questions
    Okay my cooling fan is not working and I am trying to do some tracing and checking.
    My Question is where is the K9137 Fan relay and which spot is in in?
    Second where can I find the Motronic temp censer?
    If I can find them I can trace where my problem is. Thanks to anyone that has the info, I have the print of the circuit but can not find where these things are.
    May bypass the cencer and put in a switch so I can just turn it on when I need it have done that before with a older Goldwing.
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Quote Originally Posted by Motor unit 7 View Post
    First of all if your bike is an 1150 read on, if it is an 1100 you have a mechanical switch on the oil cooler line distribution block.
    The temp sensor is on the top right of the engine right beside the oil cooler feed line (brass body). It is part of the RID system as well as an input to the Motronic for fuel management.
    The relay is under the tank I believe
    If your RID is reading correctly and the bike runs ok then the problem is somewhere else or the bike is not getting hot enough.
    FYI I tried to test this circuit on my GS 1150 and found that pin 17 never sinked to ground even at 10 bars which is way too hot IMO.
    See this post on ADV http://www.advrider.com/forums/showp...8&postcount=64
    I did some searching and found little on the turn on temperature except comments like "it rarely if ever came on" and "it's only come on once".
    Schematic below
    Ufda happens..........
    Nov 2006
    Thumbs up R1150rt-p
    Schematic below
    Yes it is a 1150 and thank you, I had found the Schematic which is really not that much of a help, I checked the fan motor yesterday (Working good) and from what you say I might just be best to put in a switch and turn it on when I need it. I did a injector balance last year and the fan never came on also went out west last year in 110 degree temp and had my concerns.
    Thank for the info much appreciated
