Results 1 to 2 of 2
Thread: 91 K75RT tachometer erratic
    Belton Tx
    I have noticed a couple of times the tach jumping to 2-3000 rpm after a cold start. There is no actual increase of rpm during this tach movement.
    Is this a sign of a problem with the ignition (HES)?
    Ron
    91 K75RT ABS
    Apr 2012
    Los Angeles, CA
    If the engine is behaving normally, I'd guess it's more likely an electrical connection at the cluster's plug, or within the cluster.
