Results 1 to 6 of 6
Thread: Master Cylinder rebuild 78 R100/7
    Dec 2012
    Any advice or help on rebuilding the brake master cylinder on my 78 R100/7? I ordered the kit, should be here today, for the 14mm cylinder (I have a single brake rotor).
    Any videos/articles out there?
    What should i NOT do?
    Thanks in advance.
    No longer a member here
    Apr 2006
    Jim: It is a straight forward job for anybody with a little mechanical experience around motorcycles (which i know you have!), which does not require much instruction. Don't spill any breakfluid on the frame or other painted parts.
    Feb 2013
    I just finished this on a cylinder that had been sitting for several years. Someone has a very good tip about using dental floss to install the captive seal on the piston. I cannot remember where I read it but maybe someone else knows.
    Mike V. #30064 30064's Avatar
    May 2006
    San Diego, CA
    Jimmy,
    Here's a picture link to my rebuild of the M/C recently. I would throw in an additional suggestion with the addition of an old caulk gun tip cut to length for the assembly of the rubber cup on the piston spool. Works a charm. Good luck with the rebuild.
    http://tinyurl.com/by4b8pj
    -Mike V. / San Diego
    Mike V. / San Diego
    MOA#30064 / ABC#11027
    78 R100/7 [orig. owner] / 81 R65 [restored]
    ABC-MOA-AMA-VBMWMO / http://tinyurl.com/4df7hgs
    Dec 2012
    WOW again!
    You guys are great!!
    I had forgotten that dental floss trick, and using the calking tube tip is really neat.
    I plan on doing this starting early Sat. morning.
    The advice about the brake fluid and paint is good.
    Mike, did I once hear you say to use DOT 4 and NOT DOT 5?
    Thanks again to all of you.
    I am amazed at how easy it is now to get great first-hand advice from first hand mechanics and also from some of you old geezers than it used to be when I was a member some 25 to 30 years ago.
    Its like having a wealth of knowledge right here at my fingertips.
    May 2006
    San Diego, CA
    Jimmy,
    Dot 3 or 4. Preferably Dot 4. Not the Dot 5 Silicone base. Be sure to change it annually. You know it's hygroscopic and absorbs ambient moisture which is cancerous for our brake's internal organs. Dot 4 has a higher boiling point - not that we need to concern ourselves so much about that for normal riding habits.
    Remember the key to M/C and Caliper rebuilds is; clean, clean. clean.
    -Mike V.
    Mike V. / San Diego
