Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: 2007RT, Did the Canbus eliminate fuses?
  1. #16
    Nov 2011
    Central Ohio
    I've never heard of a ZFE being damaged or needing replacement. Apparently it can take care of itself...
    Larry
    2006 R1200RT
  2. #17
    This is a different misunderstanding, but OK.
    If you think there is a missing fuse between the ZFE and the headlight, there isn't. The ZFE acts as a circuit breaker for that part of the circuit.
    If you think there is a missing fuse between the battery and the ZFE, then you misunderstand the whole concept of overload protection. Protection is not to protect the device; if the device is drawing too much current then it is already bad. Fuses and the like protect the wiring that feeds the defective device which is trying to draw too much current.
    So when you ask, "What protects the ZFE?" what is it that you think the ZFE needs to be protected from?
  3. #18
    Quote Originally Posted by lkraus View Post
    BMW's aren't the only motorcycles to have an onboard computer. All electronic fuel injection bikes have them but use names like ECU. Just an extremely large scale integrated circuit specialized computer with a lot of analog to digital stuff. Bike computers do get fried from time to time. Most if not all have protection circuits built in; however, just like fuses and circuit breakers you can still fry a circuit depending on what type of transient occurs. Having items turn themselves on and off by CAN Bus circuit isn't all that new. What it does do is add things that can not be repaired in the field. One of the good reasons for buying a GS911 is that wonderful ZFE can set an error code that will leave you dead in the water, but the GS911 can put you in the "limp home" mode.
    Old But Not Dead
    Semper Fi
  4. #19
    Quote Originally Posted by chewbacca View Post
    What on earth are you talking about? Can you give a factually-based example?
  5. #20
    Registered User BernieEcht's Avatar
    Jacksonville, Fl
    He is fantasizing, the GS-911 can't get you limping home. All it will do is maybe tell you what module has a fault. It will not let you operate the bike, by bypassing the defective module/part.
    It is only a diagnostic device, not a programmer or replacement for a burned ECU.
    Let's go back to 6 volt systems with candlelight head lights.
    Bernie Echt
    Jacksonville, FL
    2007 R1200RT Double Silver, 2000 R11RT sold (103K)
    MOA#92589, BMWNEF, BMW Outriders, BMW-RA, AMA
  6. #21
    The purpose of a fuse or circuit breaker is to limit the amount of current passing through a circuit. LOOK AT THE CIRCUIT DIAGRAM and you will see there is no fuse or circuit breakers BUT the circuit goes THROUGH the ZFE. As you said the ZFE operates as the circuit breaker. That built in circuit breaker has design limits. Exceeding those limits causes bad things to happen. A microprocessor is pretty delicate and lots of current tends to be hard on them. The circuit breaker and for that matter a fuse depends on tripping rapidly. If it doesn't the entire circuit that is involved heats up. Commonly called frying. If you think this is BS, do a search on "motorcycle ECU fried", it happens to cars too. My position is that yes, Canbus "could" eliminate fuses, but do you really want it to? I'm sure you won't understand that.
    http://www.r1200gs.info/R1200GS-WD2.pdf - Wiring Diagram
    http://www.bmwra.org/otl/canbus/ - how canbus is implemented on R1200gs
    CANBus is a protocol, period. What does that means? You can do the homework and find out. Does it make your bike faster? No! Does it make it more fuel efficient? No! Does it make it more reliable? Yes and no.
    Old But Not Dead
    Semper Fi
  7. #22
    Quote Originally Posted by BernieEcht View Post
    All 35 watts worth...
    And no fuses to protect against "major power", either.
  8. #23
    chewbacca,
    i'm not sure you're actually a real person but I'm giving you the benefit of the doubt. You've proven my initial comment several times over now, you're evading questions, and your posts are't even consistent with themselves. I'm sort of glad you found my article but it certainly wasn't the source of your bizarre bit of fabrication regarding ZFE and GS911.
    The forums are here for the benefit of club members. You have a question, fine, you have some knowledge to share, fine. I have no idea who could possibly benefit from your posts, yourself included.
    I hope your next foray into a technical thread goes better, but I'm out of this one.
  9. #24
    Spring Lake NJ, USA
    chewbacca,
    There are many ways to accomplish the same goal. BMW picked CanBus to provide communications between intelligent modules on the bike, and uses electronic circuit breakers to protect the bikes wiring. Other bikes use different systems, as do cars. Personally I think BMW made an intelligent choice, which may not be popular with some riders used to fuses and branch-circuit wiring harnesses. It's fine to have that opinion, but in this case BMW isn't going to revert back to it, and many people find the improved reliability a real plus in the real world. As was also pointed out - the GS-911 is a diagnostics device, not at this point a programming device, and there is no "limp-home" mode on the bikes that it would be capable of enabling. Also - CanBus does NOT eliminate fuses. It only provides communications. A solid-state circuit breaker (as used in the ZFE) monitors the current flowing to a circuit and if it exceeds a predetermined value, it shuts that circuit off. Just like a fuse - but much faster, and automatically resettable when the fault is fixed. The ZFE does not control the engine - that is a different module entirely (and it could be referred to as a ECU, except BMW likes to use different names, and it's the BMSK or BMSK-P.)
    As I mentioned before - the failure rate of ZFE modules seems to be about zero. If you have any info to the contrary, I'm all ears - but minus that, it's a non-issue, and at this point, I'm considering closing the thread. It isn't terribly productive to have arguments about what BMW has already done, and is not going to un-do in a technical forum.
  10. #25
    Riding where it's hot! AZ-J's Avatar
    Mar 2007
    Scottsdale, AZ
    My '07 now-lemoned F800S probably had a faulty ZFE but after replacing the Can-Bus, BMW bought the bike back, not taking the ZFE as a chance.
    Now I have a much better bike.
    My bike shown here
    Jordan M, MOA #24434
    My Blog
