Results 1 to 14 of 14
Thread: "DEAD" storage battery life question.......
    Registered User 032846's Avatar
    Jan 2013
    Central Florida
    I am leaving my 99 R1100R in a friends non-electrified barn for 6 weeks / the battery is fully charged......will it still be after 6 weeks of non-use and no "tender" possible..??
    opinion,please.....
    MANY THANKS TO ALL YOU RESPONDERS . TURNS OUT THE STORAGE PLACE HAS ELECTRICITY; THUS MY TRUSTY BATTERY-DOC WILL KEEP THE BATTERY AT "PARADE REST" UNTIL I REJOIN MY BIKE MID-JUNE FOR A SUMMER OF NEW ENGLAND RIDING FUN !!
    Ken ken e's Avatar
    Jul 2006
    Virginia
    A good battery should hold a "starting" charge for 6 + months. It will be fine...
    Just put a cover over it for dust and check for critter nests or stash under the seat and in the air box before starting.
    Ken E.
    2012 R1200RT
    '09 RT, '93 K75, '69 R60US and others long gone....
    I'm mostly with Ken.
    If it was critical to be certain to be able to start the bike I might disconnect the battery.
    If the barn gets stinkin' hot I'd maybe take the battery out.
    I'd probably put Stabil in the fuel.
    I wouldn't worry about it, I'd just deal with whatever problem on return.
    Mike Marr
    I don't think there are a lot of parasitic loads on an R1100R but there are some. So I would disconnect the negative lead from the battery. It should be fine for 6 weeks under those conditions.
    RAINEY 187132's Avatar
    Sep 2012
    Grand Rapids, MI
    I also vote that you will be fine. I probably wouldn't even disconnect anything either. If the battery is in good shape it should hold up
    Jason
    Grand rapids, MI
    2012 BMW R1200RT
    Quote Originally Posted by PGLAVES View Post
    That is what I'd do, too.
    Quote Originally Posted by Ken E View Post
    Ken, I see your icon is a hexhead. Assuming that is your bike have you actually measured the parasitic load and compared it with the size of your battery? I have. My '05 GS is good for 3 weeks. It might start after 6 weeks of sitting, but I wouldn't count on it.
    Swamp Fox GeneT's Avatar
    Oct 2004
    South Florida
    Battery
    I see the key word is "if battery is in good condition" Well if it were mine I would remove the battery and take it someplace where you can connect it to a battery tender. Note: Fully charged batteries last longer.
    Gene T
    Canada and the Alps
    Similar motorcycle; my R1150 GS Adventure with a battery in good condition will drop 0.1V in about 4 weeks. I have a voltmeter connected directly to the battery so I can check as I walk by. It'll start at 12.9V and it'll be 12.8V about 4 weeks later.
    Left Coast Rider
    Nov 2011
    I'm all for disconnecting a battery lead, but....
    Why don't you just let your friend use it for those 6 weeks? I mean, he's your friend, right? That way I'm sure the battery will be fully charged when you get back.
    No longer a member here
    Apr 2006
    Don't underestimate the drain for the clock ( Does the R1100R have one?) If I store one of my BMWs for longer than a month, I put a tender on them.
    Sep 2008
    Wilmington, NC
    Got no idea what the parasitic drain is on that model but a few months ago dealt with a K1200RS that had a very flat Odyssey in it when the owner had kicked loose the charger cord over the winter and not noticed it- was probably without charging for about 3 1/2 mths which is a good deal longer than you expect- but normally a disconnected Odyssey on a shelf has no problem holding a solid charge for more than twice that long...
    Disconnect it to be safe unless you've got a handy way to jump it if the battery won't fire it...
    I have a BatteryMINDer #12248 charger. Been using it for years on my car and now on my bike battery (using the GEL setting). After it brings a battery up to full charge it goes into a "de-sulphator" mode which the manufacturer claims will bring back most batteries dead sulphated batteries to new condition using a high frequency signal.
    Bluenoser
    Mar 2010
    Lethbridge Alberta
    I'm with the disconnect the battery cable crowd.
    1999 R1100s
    Out There Somewhere ricochetrider's Avatar
    Apr 2008
    Harrisburg, PA
    IF is a big word...
    IF it's in decent condition...
    IF it doesn't get too hot...
    IF this
    IF that...
    One way to be ABSOLUTELY certain...
    Take the battery with you and keep it on trickle charge at home for the duration. Six weeks is going to be PRIME riding season.
    Why chance it?
    Be The Change You Want To See In The World
