Results 1 to 4 of 4
Thread: Rukka Airway Jacket Review
    na1g
    May 2011
    Webbikeworld.com just posted a review of the new Rukka Airway Jacket and matching pants. These are vented and , as you would expect from Rukka, high-tech and top quality. In the market for some good vented gear? Check out the review. The bottom line: jacket = $899, pants = $699 so you won't see me in this stuff, but wish I could spend that much.
    Related question: why do manufacturers of vented gear give you a waterproof liner that goes inside the vented shell. Wouldn't it make more sense to use an outer waterpoof shell so that A) you don't have to take the jacket off to put on the waterproofs? and B) the vented jacket stays dry?
    pete
    "Be yourself. Everyone else is already taken." - Oscar Wilde
    Quote Originally Posted by na1g View Post
    Much waterproof gear, especially those with a "breathable membrane", is somewhat fragile, at least when compared to the shell. A waterproof liner that tears is soon not waterproof. It's also quite expensive. Putting it inside the shell helps protect the expensive liner from wear and tear.
    Liners on jackets aren't too bad. I can remove a jacket, put on the liner, then put the jacket back on pretty quick (although I no longer have to since I returned to the Riders Wearhouse fold). Liners for pants, on the other hand, are crazy. While standing in the rain I'm supposed to take off my boots so I can take off the pants to put on the liner, the pants, and then boots now full of water. If the liner wasn't in the pants when I left for the ride I wound up using external rain pants.
    Here is one with a water proof outer shell. Anyone try it?
    Tourtech,
    http://youtu.be/L620UNHRjGg
    BMW Airflow suit assumes use of BMW rain suit as the outer "wind stop."
