Results 1 to 10 of 10
Thread: 1990 R100RT driveshaft bolts
    Are the 4 driveshaft bolts throwaway or can I reuse them with blue locktight? The bolts did not have lockwashers.
    Clymer states they are throwaway.
    Thanks Bob
    Aug 2007
    Somers, CT
    Driveshaft bolts
    They are suppose to be throw away. No lockwashers is correct.
    Jim
    Administrator 20774's Avatar
    Clymer would have to say they're throwaway. A dealer would and a mechanic working on these bikes for a living would also tell you to throw them away. For obvious reasons.
    The new short bolts were tested by BMW and found to be good replacements for the longer bolts with lock washers. They are designed to stretch, which is what helps to keep them from loosening...this is the basic premise for many bolts. If not stretched to the point of yielding where they plastically deform, they should essentially be the same bolt once the stretch is removed.
    How do you know if the bolt has plastically deformed? One way might be to hand thread them back into the output flange. If they thread easily with no hang ups, they're probably just fine. Otherwise they might be an issue.
    Your call. Blue loctite will help even with fresh bolts...belt and suspenders. If you don't want the worry about bolts loosening, get new ones. Not really that expensive in the long run.
    Snowbum's discussion here:
    http://bmwmotorcycletech.info/drvshf...oolstorque.htm
    Smile Thanks
    I will order new bolts small price for peace of mind.
    Cheers Bob
    Fenwick, Ontario Canada
    I have reused my driveshaft bolts many times.
    As an industrial metallurgist I have faith in my judgement.
    I have a spare set to replace if needed.
    When you can't thread them in by hand easily the threads have deformed.
    That is the point when I replace them.
    Knights of the Roundel #333
    Curmudgeon nrpetersen's Avatar
    Sep 2004
    minnetonka mn
    Lockwashers are a tool of the devil in any loaded joint with short fasteners. I'm amazed that BMW got sucked into using them at this location.
    I reused these non-washered bolts too, but my R90 has low compression pistons. If nothing else, it depends on how you expect to drive the bike.
    Retired w 2005 K1200LT, 2000 R1100RT, & 1975 R90/6
    spencer
    Driveshaft bolts
    I have ridden many, many airhead miles and wrenched on dozens of post-1980 airheads since 1981.
    Probably removed and reinstalled hundreds of driveshaft bolts.
    Have never bought a new driveshaft bolt in all that time.
    And I am still alive.
    Either I am quite lucky.
    Or maybe, and most likely, not reusing driveshaft bolts is just one more overblown airhead issue.
    Registered User kioolt's Avatar
    Maryland
    Are we actually talking about the u-joint bolts?
    2004 R1150RT 169,000 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 404,600 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    Quote Originally Posted by kioolt View Post
    No, the bolts at the forward end that connect the driveshaft to the output flange from the transmission.
    Maryland
    That's what I would call u-joint bolts because they bolt the u-joint flange to the output flange.
    AMA,BMWRA,BMWMOA
