Results 16 to 24 of 24
Thread: Quick $2k O-ring Question
    Vancouver, B.C. Canada
    [QUOTE=brittrunyon;870873]I now have a 1981 R 100 & changing the oil for the first time.
    I read http://www.largiader.com/tech/filters/ & have come up with this.
    The canister depth is 3.1.
    It appears to be the squared, not rounded.
    So I plan on using a white o-ring with a shim to protect it & no gasket.
    This would compress the o-ring by about 25%.
    Is my logic flawed? [/QUOT
    In looking at Anton's canister chart
    http://www.largiader.com/tech/filters/canister.html
    it seems to me if your canister depth is 3.1 and you have the sharp (square) edged canister then you should be installing your filter, one shim, the white O Ring, a paper gasket and your cover. In that order.
    Last edited by Happy Wanderer; 04-19-2013 at 06:37 PM. Reason: Two posts while I typed this one.
    The shim is incompressible so you really need to compare 4.0 and 2.8, if you want to know the compression. However, I think the compression stuff is misguided (I think I explain some of this on that page) so I don't use it.
    Anton -
    You say it's misguided, but yet you came up with recommendations for shims, gaskets, etc. How did you decide on these configurations without considering how much "squeeze" there would be on the white o-ring?
    From your website, "..so it's really unnecessary to apply this level of precision. You need to compress the O-ring, but it's not rocket science." But there has to be some consideration for the numbers to ensure that you have "some" compression. Maybe using Airhead science??
    '92 R100GS '81 R100/t brittrunyon's Avatar
    Sep 2009
    Ojo Caliente, New Mexico
    So with those #'s the compression is 30%.........?
    If that's too much, what results?
    And I only thought I had a "Quick $2k O-ring Question"
    1992 R100 GS, 2007 F 650 GS
    Big Bend Ride video at http://brittrunyon.com/
    More riding videos @ http://vimeo.com/user2721333/videos
    You say it's misguided, but yet...
    The compression percentages, I personally feel are misguided because the O-ring is compressed radially before you even get to the canister depth. Traditional O-ring compression specs don't have that complication. So, I refer to millimeters of compression or just groove depth and I get those from my own experience and trusted anecdotal data. I shoot for 3.5/0.5, and I don't really want to go more than 3.2/0.8. So to answer my own question, you went wrong not only by miscalculating the compression but by bringing some compression % spec into the picture to begin with. That wasn't in the article.
    Later canisters which are not fully seated (an incredible oversight by BMW) can be pushed too far inward, and I think the O-ring compression is driving force for that.
    Quote Originally Posted by brittrunyon View Post
    Yup.
    Anton -
    Yes, you do discuss a groove depth, somewhat in context with the compression of the o-ring. So, OK, we shouldn't focus on compression of the o-ring, which Oak had written about in one of his Airmail articles.
    But taking your numbers from your website, and computing the compression values per the basic equation, I get the following table. Interesting, your recommendation of groove depth matches quite well Oak's recommendation of compression values of between 10 and 25%.
    So while compression might not be the best way to think about this, it does appear that the two different scales really give the same range of recommendations for stack up of components.
    Another question...why is there a need for a chart for the rounded edge canister and one for the square edge canister? It's all about the initial canister depth...seems to me the shape of the edge really has nothing to do with what stack up of components is needed.
    Sep 2009
    WOW, now that's some math.
    I'll try and wrap my head around it & apply as best I can.
    Thanks for the comparison.
    ... your recommendation of groove depth matches quite well Oak's recommendation of compression values of between 10 and 25%.
    If you actually read the page, you'll see that those are examples targeting an arbitrary 3.3mm groove depth. That's not a recommendation and I explain elsewhere why I use a larger number. The purpose of the whole page is to get you to do your own math. That's why I was more interested in knowing how the OP came up with his conclusion than I was in actually doing the work for him.
    The O-ring packs fully with about 0.5~0.6mm compression. There's no need to go much tighter. This is explained on the page.
    The sharp-edge canister cannot offer a no-shim option, so the contents of those six rows are different.
    Sep 2009
    Thanks for doing all the work & sharing your the info on the $2k O-ring saga.
    I wasn't looking for you to do the work for me. I was wondering if my thinking was correct.
    But I guess in a way that's asking someone to do a little work.
    "The O-ring packs fully with about 0.5-0.6 mm compression" That's good to know, I must have missed that when reading your page.
    Thanks Again.
