Justscootin
Jeff Wilson life member
I bought a Garmin gps 350lm as they have a $100 rebate on them till June 30th and I hard wired it to the battery. When removing the colored panel in the center of the handle bar I found a cross bar that has a plug on it. Is this plug for the BMW gps as if it is I was thinking that I might cut into the wires as this plug the power would probably be the 5 volts needed and it would be turned off with the ignition.
Any thoughts?
Any thoughts?
